Here it is...the SCSI2SD adapter with 16GB microSD Card mounted on the hard drive bracket.
You just Need to plug the SCSI cable and it gets the +5V from the termination power (o;
When you buy the SCSI2SD adapter you just get the board, no cables, screws, Adapter, quick start sheet....nothing...just the bare board.
It would be nice if the board could be mounted with a male socket so it could be plugged in directly to the SCSI board.
