Author Topic: Aeroflex SGD-3 Digital Signal Generator. What's 100 ohm differential inputs??  (Read 1732 times)
Offline ErnieEngineerTopic starter
Aeroflex SGD-3 Digital RF Signal Generator. Would you recommend?
Looking to buy a good general purpose vector signal generator. I really need vector modulation (from IQ inputs) and generic modulation ( PSK, FSK, QAM). I think  that this Aeroflex SGD-3 fits the bill. Includes most of the options which is great. I also like that it has a nice UI and the user manual is pretty simple.
What is up with I/Q inputs tho? It has " I+, I-, Q+, Q- IN Four BNC sockets, differential inputs, 100 Ω. " Looks like there are four normal looking BNC connectors for this on the front panel. I just want to hook this thing up to a AWG with normal outputs. Would I need some kind of adapter?
https://www.ebay.com/itm/Aeroflex-SGD-3-Digital-RF-Signal-Generator-100-kHz-to-3-GHz-w-options/
https://www.valuetronics.com/product/sgd3-ifr-rf-generator-used
https://aeroflex.viavisolutions.com/support/technical-support/product-support-documents/sgd-digital-signal-generator
https://www.viavisolutions.com/en-us/products/discontinued/sgd-digital-signal-generator-discontinued
The following users thanked this post: ErnieEngineer
Yes, that one from Aeroflex. I entered the link wrong. Already have an AWG very similar to the one you linked to. I am looking for a proper RF signal generator that I can produce QAM and SSB (and others) at up to a few GHz. Really confused about the 100 ohm IQ inputs. Never saw that before on an instrument .
If you're not in a desperate hurry Siglent have an RF gen coming out soon that apparently links together with SDG6000X models so to give IQ at higher BW's.
https://www.eevblog.com/forum/testgear/siglent-ssg3000x-series-rf-signal-generators/
This Chinese site won't allow direct translation but you can copy/paste anything into a translator that needs further investigation.
http://www.siglent.com/RF-Generator/SSG3000X
Been asking when it's to be released but no definitive answer yet.
Offline ogden
  • Country: lv
MSRP?
p.s. I wish I had 4k$ because eBay offer is Goood: You save: $52,346.91 (93% off)   :-DD
