Author Topic: How to use sigrok and gnuplot  (Read 1751 times)
Offline HoracioDosTopic starter
  • Country: ar
  • Just an IT monkey with a DSO
« on: October 18, 2018, 09:56:42 pm »
I would like to share this example about how to use sigrok and gnuplot. I did this without any particular purpose. I know that there are more useful examples than reading values from a Korad but perhaps someone would fine it useful.
This simple bash script (getdata.sh) gets data from a Korad PSU with sigrok and it creates an output file.
#!/usr/bin/env bash
echo 'Starting ...'
sigrok-cli  --driver=korad-kaxxxxp:conn=/dev/ttyACM0  --set --config enabled=off
echo 'Setting Voltage'
sigrok-cli  --driver=korad-kaxxxxp:conn=/dev/ttyACM0  --set --config voltage_target=9
echo 'Enabling Output'
sigrok-cli  --driver=korad-kaxxxxp:conn=/dev/ttyACM0  --set --config enabled=on
echo 'Logging'
sigrok-cli --driver=korad-kaxxxxp:conn=/dev/ttyACM0  --continuous -o /tmp/data.dat -O csv
trap "{ echo 'Quit...' ; sigrok-cli  --driver=korad-kaxxxxp:conn=/dev/ttyACM0  --set --config enabled=off ; exit 255; }" EXIT
Then Gnuplot script (demo.plt) reads the last 50 lines of the output file while sigrok appends new lines at the end in an infinite loop until the escape key is pressed.
# set title "Test"
# set title  font ",20" norotate
set datafile separator ','
set yrange[0:0.03]
set autoscale x
set ylabel "A"
set xlabel "Samples"
set grid
bind "Escape" "unset output; exit gnuplot"
plot "< tail -n 50 /tmp/data.dat" using 3 smooth acsplines title "I"
pause 1
reread
Execute gnuplot ./demo.plt to plot data. Remember to Quit by pressing Escape key.
  • Country: ar
Re: How to use sigrok and gnuplot
« Reply #1 on: October 19, 2018, 12:45:51 pm »
This is a brymen 257s logging voltage.
#!/usr/bin/env bash
echo 'Logging'
sigrok-cli --driver=brymen-bm25x:conn=/dev/ttyUSB0 --continuous -o /tmp/data.dat -O csv
trap "{ echo 'Quit...' ; exit 255; }" EXIT
Brymen plot script
set yrange[8.980:9.010]
set autoscale x
set ylabel "Volts"
set grid
plot "< tail -n 50 /tmp/data.dat" using 2 smooth acsplines title "V"
pause 1
reread
Korad again with two y-axis
set yrange[0.01:0.03]
set y2range[0:12]
set autoscale x
set ylabel "Ampere"
set y2label "Volts"
set ytics border nomirror
set y2tics border nomirror
set grid
set key box lt -1 lw 1
plot "< tail -n 50 /tmp/data.dat" using 3 smooth acsplines title "I" , '' using 2 with lines axes x1y2 title "V"
pause 1
reread
« Last Edit: October 19, 2018, 06:54:03 pm by HoracioDos »
