Author Topic: How to properly discharge my scope's CRT?  (Read 4011 times)
Offline parabuzzleTopic starter
« on: October 23, 2013, 02:39:04 am »
Hello,
I want to replace the caps in my old school scope's power supply but before I work in that section, I think it best to discharge the CRT... I found this video showing someone doing it in an extremely unsafe looking way ()
How is one supposed to render the CRT safe to work on the power supply?  :-//
btw, I have the Philips PM3216 scope if that makes any difference.
-Mike
Re: How to properly discharge my scope's CRT?
« Reply #1 on: October 23, 2013, 03:01:13 am »
Mike
The UHT side of quintupler (PDA(post deflection acceleration)) is where you need to go.
A short jumper lead grounded and connected to a screwdriver and gently slide under grommet on CRT where lead ends.
Be gentle with grommet and CRT
Plus any big electrolytic you feel threatened by :o
 Rob
Offline Stonent
« Reply #2 on: October 23, 2013, 03:40:37 am »
I've seen TV repairmen use a long screwdriver wrapped in tape where just the tip of the metal is exposed. Underneath the tape is a piece of lamp cord wrapped around the screwdriver that is grounded to the chassis or ground point on the tv. They just slip it under the cup and wait for the snap sound. Then repeat until there are no more sounds.
Offline c4757p
  • adieu
« Reply #3 on: October 23, 2013, 03:47:53 am »
I clip one end of a wire with alligator clips to the chassis, then slip the other clip under the anode cup. Once I'm sure it's made contact a couple times, I bend the cap back a bit and attach the clip to the connector, just to make sure it stays discharged.
It's just a scope CRT, it's charged to a somewhat lower voltage than a bigass television tube and has less capacitance. You still don't want to go sticking your tongue in the anode port, but other than that there's not much to it. Ground it for a minute and you're done.
« Last Edit: October 23, 2013, 03:51:00 am by c4757p »
Offline ddavidebor
    • Smartbox AT
« Reply #4 on: October 23, 2013, 05:23:58 am »
Well, clips are not exactly safe. If you use the crappy one and it doesn't hold on the chassis and felt down, you get zapped.
David - Professional Engineer - Medical Devices and Tablet Computers at Smartbox AT
Side businesses: Altium Industry Expert writer, http://fermium.ltd.uk (Scientific Equiment), http://chinesecleavers.co.uk (Cutlery),
Offline amyk
« Reply #5 on: October 23, 2013, 05:59:18 am »
The CRT won't bite unless you touch the HV connector. I wouldn't discharge it unnecessarily if I'm not working on it. If you are, be careful as it may charge up again on its own (due to dielectric absorption) if not constantly shorted.
Offline BravoV
  • +++ ATH1
« Reply #6 on: October 23, 2013, 06:53:36 am »
+1 :-+ , the devil is in the detail, learned this too from my mentor which was a TV repairman.
« Reply #7 on: October 23, 2013, 07:02:46 am »
You are quite right, however often the cable winds its way through the chassis and needs to be disconnected to access PCB's for removal/repair, especially the more upright types.
But if you are not working on the tube area leave it be.
« Reply #8 on: October 23, 2013, 02:05:55 pm »
Wow.. I would hate to learn that CRT's can recharge on their own the hard way ;)
« Reply #9 on: October 23, 2013, 02:06:50 pm »
Bingo... it winds right over one of the caps I want to replace :/
Offline Neilm
« Reply #10 on: October 23, 2013, 05:41:23 pm »
All capacitors will exhibit this affect. It is just more apparent with high voltage ones. (i.e. it hurts). Quite often you will see people leaving shorting links across capacitor pins to prevent this.
Two things are infinite: the universe and human stupidity; and I'm not sure about the the universe. - Albert Einstein
Tesla referral code https://ts.la/neil53539
