From my weak understanding of it, if the sampling rate is less than (or equal to) the Nyquist value (400MSa/s for 200MHz etc) then the waveform will be distorted and useless. However, oversampling, as far as I'm aware, is not meaningless. So the more the merrier.
The DS2000-Series has 2GSa/s sampling rate. That's 1GSa/s for each channel. Sampling is 5X max bandwidth (200MHz) >> 2X, so it should be good
