Author Topic: Hacking the Rigol MSO5000 - Dr Mefisto Licensing Method  (Read 11523 times)
SpacedCowboy and 1 Guest are viewing this topic.
Offline BTOTopic starter
Re: Hacking the Rigol MSO5000 - Dr Mefisto Licensing Method
« Reply #100 on: July 17, 2024, 06:24:08 pm »
ANY QUESTIONS ?
 8) At least not at this very moment! Your dedication is awesome, a thousand thanks go out to you for these answers!
I've found the BACKUP DUMP reference in STEP 8 of the PDF, and I'll work further with your latest post and the PDF to understand more of all this. And then I'll be watching the 13 videos you've prepared  :-+
The PDF HAS BEEN UPDATED....
I have attached the updated version for you , Discard the old one.
- Cool
- You're welcome, it's not a problem, I Enjoy doing this .
- it's actually STEP 6,  STEP 7  and STEP 8 Combined,   Don't just skip to Step 8
- No Problem, In your own time.
- Cool, i hope you enjoy them, there's a lot of cool stuff there about your scope, and there's some useful electronics troubleshooting as well,
  Real world practical examples on how to use your scope when measuring things, Timings, Calculating inductor values and things as such.
if you have any questions, Ask me !
Be cool
QUESTION EVERYTHING!!!
« Reply #101 on: August 05, 2024, 12:40:10 pm »
QUICK UPDATE
PAGE 1 POST OF THIS THREAD HAS BEEN UPDATED
- To Reflect The Correct CURRENT procedure for Correct Licensing of the scope
- To make obsolete the "Hacking Method" that does not survive firmware upgrade - it is still useable, Just not advised
- Firmware File has been upgraded to the latest 2.10b version
- Firmware and instructional pdf has been added to the attachment on post 1
- All outdated steps have been striked out
Offline sdouble
« Reply #102 on: August 09, 2024, 05:54:56 am »
I would like to thanks all of you guys for the effort you put into that work.
I ordered some MSO5074s and plan to upgrade them.
A stupid question though  :-[ : is the router absolutely needed ? A direct ethernet connection would not work ?
Best
« Reply #103 on: August 09, 2024, 06:24:48 am »
Best
- You're Welcome, Much appreciated
- Cool
- THERE ARE NO STUPID QUESTIONS....
well... I mean... LOL
Unless you ask then i repeat then you ask and i repeat and we do that 15times
That would be stupid  :-DD
But.... As you were  LOL
This is a catch-22 question and answer.
You see (Before i give you the answer)...
What you're talking about required a "Cross over Cable" which works on a Peer To Peer Topology.
This is basics of Networking.
Now.. if you were familiar with the basics of Networking YOU WOULDN'T BE ASKING THIS QUESTION.
If you were familiar with Crossover Cables and the OSI Model, this question wouldn't exist
SO FOR YOU
FOR THE SAKE OF NOT BRICKING YOUR SCOPE
FOR THE SAKE OF STUPID CRAP NOT HAPPENING
MY OFFICIAL POSITION IS............ YES FOR YOU A ROUTER IS ABSOLUTELY NECESSARY
The I.P. Address is required, Because of how the script works.
INTERNET CONNECTION HOWEVER... IS NOT REQUIRED
So, to be clear, You can pull some shitty router out of the garage and all you need is
ROUTER
POWER SUPPLY
ETHERNET CABLE
Router cannot be in Bridge mode (Must be in Router Mode with DHCP Enabled)
But, Internet is not required
LAN Connection is required,   don't go down the WiFi Road
You can find routers on gumtree for Free if you don't have one, but i'd be asking...
How the hell are you on this forum if you don't have a router ?
Hope that helps
Offline sdouble
« Reply #104 on: August 09, 2024, 08:18:20 am »
Dear BTO,
Thanks for your thorough response.
As you kindly noted, my experience with networking is limited. I frequently use high speed ethernet switches to connect various equipment (including relatively fast digitizers), but clearly, network technology is far from my area of expertise (which is primarily experimental nuclear physics).
Is it a problem if I don't have a internet connection ?
Don't jump on me, just kidding.
I mentioned that fact that i'll be getting MSO5074s very soon. Actually I'll get a set of 4 with the current option bundle at work.
Big lab, no available router there. Or, to be more precise, not allowed to connect to any of the routers there.
I may bring a router from home for the very purpose of upgrading the scopes though.
« Reply #105 on: August 09, 2024, 01:43:08 pm »
Dear BTO,
- You're Welcome
- Indeed, and i assure you the comment was made with all the best intentions :P
- Fair enough, we all start somewhere
- Soooo.... You're saying..... You don't really have that much experience   :-DD
- if it's a question pertaining to activating your scope......NO PROBLEM AT ALL, NOT IN THE SLIGHTEST
- I was going to applaud you for learning  :clap:
- OK,  AND... OSCILLOSCOPES ARE NOT ALLLOWED TO BE HACKED...........................................WHAT'S YOUR POINT  :-DD
2. If you merely connect to the ethernet port , WHO'S GONNA KNOW and... What if you do , You literally need to be connected for 2 - 5mins
    If i were you, i'd connect and upgrade it like you stole it
3. if you must wimp out and "FOLLOW THE ROOLZ" then... Yes you can bring a router from home,
   After all it just needs power and ethernet cable.   No internet required.
Offline sdouble
« Reply #106 on: August 09, 2024, 01:58:41 pm »
==>>  ^-^ I would love to be less "experienced"
==>> Yep, being in the grey  zone I guess....
==>> I caught you being very wrong here. I would not do that knowing , that I don't want to be fired within hours... My lab is pretty closed...
==>> No internet required, for sure  ;D
« Reply #107 on: August 10, 2024, 12:35:18 am »
I Understand what you mean
Fair enough
ahh yes, the corporate grip on the employee   LOL
You gotta love the world we live in don't ya
