Author Topic: picoscope 3223  (Read 2121 times)
Offline scope userTopic starter
picoscope 3223
« on: May 08, 2018, 06:13:26 pm »
Does anyone know if the pico 3223 scope can run the newest version of  automotive software, version 6.12.7.2724, I have found a good used one and just curious if the older model would have any issues with the newer software.  Thanks
Offline HighVoltage
Re: picoscope 3223
« Reply #1 on: May 08, 2018, 06:28:26 pm »
As far as I know, all new pico scope software support older scopes.
At least I never had a problem, using the latest software on older scopes.
Re: picoscope 3223
« Reply #2 on: May 09, 2018, 03:41:54 am »
Thank you, for the response.
I'm looking to upgrade to a better auto scope and found a good old picoscope.
Offline _Wim_
Re: picoscope 3223
« Reply #3 on: May 09, 2018, 08:29:17 pm »
If you go to the downloadsection of the pico website, you see the 3223 is listed under the discontinued products. If you select it, you get a list to the lastest supported software packages. So I would say the lasted version is not supported any more for this one...
