Author Topic: how to connect siglent sds1102dl to computer?  (Read 435 times)
Offline sonielkrafTopic starter
  • Country: id
    • acwirosari
« on: October 27, 2024, 12:29:02 am »
hello, i have siglent sds1102dl, i want to connect my scope on computer but any problem with driver, i can't find this driver on internet, can help me? thanks...
Online BillyO
Re: how to connect siglent sds1102dl to computer?
« Reply #1 on: October 27, 2024, 01:37:15 am »
What computer do you have?  A Commodore 64?  A PC?  Apple?  PDP-11?  IBM System Z16?
What OS are you running?  CP/M?  Windoz XP?  Windoz 10/11?  Ubuntu?  Some Apple thing like DOS 3.1 or macOS 15?  VMS?
« Reply #2 on: October 27, 2024, 01:49:09 am »
Driver for what ?
Connectivity or to use with some computer program ?
Old DL models only offered USB connectivity for Windows based systems with Siglent's EasyScope SW for which you also needed to install NIVISA Runtime as a minimum for the USB connectivity drivers.
  • Country: id
    • acwirosari
« Reply #3 on: October 27, 2024, 02:13:27 am »
yes i connect windows 10, and need driver on windows system
Online BillyO
« Reply #4 on: October 27, 2024, 02:16:41 am »
google "Siglent sds1102dl software download" and pick a location near you.
Or maybe Rob will provide a link close to Indonesia.
You will need to install NI VISA.
  • Country: id
    • acwirosari
« Reply #5 on: October 27, 2024, 02:25:06 am »
ok, i try download ni visa first
Offline coromonadalix
« Reply #6 on: October 27, 2024, 08:31:33 am »
you ask  and dont provide much
if you are in windows  check in device manager for any requested usb driver,  normally    it should not be a problem
the Visa  is an interface layer
you have Ni Visa, Rhode & Schwartz,  Keysight i/o librairies   etc ....  i use Rhode Schwartz  Visa, they have simpler tools to do communications and tests
What ever Visa you use,   the scope  will still be dumb,  it depends on how you want to control it, if you have the correct softwares for it
you have posted  for firmwares and other things, i think you need to learn ??
and if it for FW recoveries  that's another thing
« Last Edit: October 27, 2024, 08:33:28 am by coromonadalix »
  • Country: id
    • acwirosari
« Reply #7 on: October 27, 2024, 05:25:10 pm »
thanks , yes i need to learn to connect to windows 10, thats why i ask on the forum, because i really to learn it, thank you
Online BillyO
« Reply #8 on: October 27, 2024, 06:05:02 pm »
Download the software for it from Siglent and all the documentation for it.  It will give you step by step instructions.
Here is the North American page for software and drivers: https://siglentna.com/service-and-support/firmware-software/digital-oscilloscopes/#sds1000-series
Here is the documentation: https://siglentna.com/resources/documents/digital-oscilloscopes/#sds1000dl-series
« Reply #9 on: October 28, 2024, 03:36:57 am »
check the hardware properties of the device with exclamation mark, and read the vid pid  of this device  you will learn what it is or what it need to work
google on how to find drivers on unknown devices etc ...  you obviously need to learn that
