hi gays...
i have huge problem by vc97...
after By mistake, I tried to test a high frequency for measurement. More importantly, Multimeter played a certain sound like start music and then the calibration got messed up!!!
In the voltage range has a permanent negative offset digit , in frequency range and the capacitor are messed up.The numbers are not as accurate as before.
All parts and transistors were checked and are OK.
i did flash the IC EPRROM with the file copied from the same like device ok, but also it did not work.
There are two point on the back of the board that go into calibration mode by connecting these two ,and calibrate process started... but I don't know Exactly how to do it.
chip is DS-HY12P66 (DTM0660)
eeprom 24c02
Dear engineers, I am asking for help. to this problem.
Thank you very much
