I’ve been at the same place with you. My options were MSO5104, SDS2104X+, and R&S RTB2004. Thanks to contributors here I read a lot, and I learned a lot. Let me share my experience with you.
I don’t have a large budget. Price/Performance was important for me. First I eliminated RTB2004. Because it is more expensive (considered with options and upgrades) and not possible to hack it in the future. Then I had 2 options left:
RIGOL MSO5104:
Pros:
+ 8 GSa/sec sample rate (it is great if you need high freq) (4 Gsa/sec with 2 channels enabled, 1GSa/sec with 4 channels enabled) (Siglent: 2 Gsa/sec with 1/2 channels enabled, 1GSa/sec with 3/4 channels enabled)
+ Easy to upgrade(or hack) for all options (including 500MHz bandwith)
+ Comes with 4 x 350 MHz probes (Siglent comes with 200 MHz probes)
+ 1 GSa/sec digital channels sampling rate. (Siglent has 500 MSa/sec)
+ 2 Channel AWG (option) (but up to 25 MHz. Siglent comes with 1 Ch 50 MHz option)
+ Better price. (and some very attractive promotions with bundle options)
+ HDMI output (but 1024x600 not scaled to fullscreen)
+ Web viewer.
+ 4 Math functions at a time (Siglent has 2)
Cons:
- The most popular one is the noisy front end. Bad for analog signals. I considered adding an amplifier. The most effective types of signal amplifiers are active/diffferantial probes. However, they are too expensive, even more expensive than the scope itself. There are also very cheap low-noise signal amplifiers. However, their problem is nonlinearity. Their gain cannot stay at the same level as the frequency changes. So you can see the shape of the signal, but cannot trust to the measurements. It depends on your requirements. If just seeing the waveform is enough no problem.
- Buggy UI and firmware. Rigol used its own ASIC chip on this model. And users report that software bugs are less now but still there.
- 100 mega points (analog) standard memory. 100 mp is a good value but less compared to Siglent. (Siglent has 200 Mp out of the box. 200 Mp/ch when 2 ch enabled. 100 mp/ch when 4 channels are enabled. Rigol has 100 Mp/ch when a single channel is enabled. 25 Mp/ch when 4 channels are enabled. However, Rigol has a 400 USD upgrade option to 200 mp/ch, MSO5000-2RL, which doubles the numbers in the previous sentence. Still half of the Siglent, even with the deep memory option purchased.)
- 25 mega points per digital channel memory (Siglent has 50 Mp/ch)
- You have to buy separately the 16 channel logic probes and to use them and it is not cheap (probes: ~400 USD). But no sw license is needed.
- You have to pay (or hack) for all protocol decoding options (sometimes there are free bundle promotions. at Siglent basic protocols are included for free)
- There is no 50 Ohm input setting. You have to use 50 ohm terminator when your source impedance is 50 Ohms.
- 1 mega points FFT
SIGLENT SDS2104X
Pros:
+ Very low noise floor (It is around 70 microvolts which is really great fun when working with low amplitude signals)
+ 500 microvolt/div range setting (which is not pixel doubling as it is in Rigol)
+ Astonishing 10.1 display with 256 level intensity grading (Rigol has 9”). Touchscreen and gestures work smoothly (I saw some videos in which Rigol has some problems with that).
+ 50 MHz signal generator (optional) (but 1 channel)
+ 10-bit mode is really working fine (also you can add ERES filter to increase the effective bits on top of it)
+ If you have a signal generator from Siglent (SDG2042X I have) scope can communicate and command it flawlessly (through the local area network) to calculate the Bode plot.
+ DIY digital logic probe schematics are available in the forum. (not sure if Rigol also has)
+ Decoding for basic (UART, I2C, SPI, … ) protocols is included for free. You have to pay for some additional protocols (I2S, Manchester, CAN FD, FlexRay, MIL-STD 1553B, SENT)
+ Stable UI/UX.
+ Web control with full screen viewing option. (There is a VNC server running on the device. From any client you can connect and view scope UI)
+ 50 Ohm input setting is there.
+ 2 mega points FFT
Cons:
- In high frequencies, 2 GSa/sec per channel might be limiting (It is 1GSa/ch when 3 or4 channel is used).
- When upgraded to 500 MHz bandwidth it is up to 2 channels at a time. If you need 3 or 4 channels simultaneously, bandwidth limit is 350 MHz.
- 200 MHz probes come with 100MHz and 200 MHz models.
- Price level is higher than Rigol. (Sometimes, also very attractive bundle promotions are there but usually still higher)
- You have to buy separately the 16 channel logic probes and a sw licence to use them and it is not cheap (probes: ~380 USD sw:~175 USD).
- No HDMI/VGA output. (You have to use web viewer or VNC)
+ Only 2 Math functions at a time (Rigol has 4)
SUMMARY:
• Both scopes are really good. You shouldn’t expect the best scope of the world at this price level.
• Both scopes are open to liberation (hack). R&S RTB2000 is not as I know.
• If you will mostly work with digital signals which don’t need more resolutions but higher sample rates Rigol has a 2 times sample rate compared to the Siglent. (2 GSa/sec when 4 channels are used compared to 1 GSa/sec). Also when you need 1 channel only 8GSa/sec should be very great at high frequencies. So with digital signals at high freq Rigol looks great.
• Having a low noise floor, effective 10-bit mode, and ERES filter Siglent is much better at analog signals (or when probing digital signals with analog probes).
• Siglent has 4 times of memory of Rigol’s in most cases. (2 times when Rigol’s deep memory option is purchased)
• Siglent is more expensive.
• Siglent has a less buggy and better UI/UX (my opinion).
• If you need BODE PLOT analysis and already have a signal generator from Siglent or Rigol you would want to consider the integration benefits of having a scope from the same brand.
Which one we should choose?
It really depends. You should consider your requirements and check the pro and con conditions above. If you only work with digital signals Rigol beats with a high sample rate and attractive price. If analog is also important and especially you need a good resolution then Siglent is better.
I usually work with digital signals but analog signal probing is also a must for me, and I didn’t wanna struggle with the noise problems when going analog. So, I went with Siglent. I bought it under a promotion price; bundled with AWG, 16 channel logic probes, and a logic probing software license. Sometimes I wonder how fun it would be if it had an 8 GSa/sec sample rate, but in common I am very happy with the Siglent.
