Poll
how can i reset the boot the sequence for MSO2024?
rebooting issue
1 (33.3%)
white display issue
2 (66.7%)
Total Members Voted: 3
Author Topic: Oscilloscope MSO2024 will not start  (Read 3590 times)
Offline hsoliTopic starter
« on: February 09, 2015, 11:25:59 pm »
Oscilloscope MSO2024 will not start .
i got new Oscilliscope was stored in the original box for long time, tried to power it up.
I got white screen without no actions or even the splash menue.
it seems that the Oscilloscope has nothing to load.
How can i reset the firmware or debug this oscilliscope?
Offline tautech
Re: Oscilloscope MSO2024 will not start
« Reply #1 on: February 09, 2015, 11:35:53 pm »
Welcome to the forum.
Check the PSU is to spec.
Check all interconnect cables.(re-seat)
Offline Hydrawerk
« Reply #2 on: February 09, 2015, 11:39:10 pm »
« Reply #3 on: February 10, 2015, 08:10:41 pm »
Hello Everyone
Thanks for your quick response.
Yes The link is correct, It is the correct mode.
PSU looks running , i can see the Fans running. I did not try to open it.
It is new device never powered before.
I tried to get the Firmware update on USB flash but it seems did not finish the full power cycle.
My questions:
What could impact the power cycle for new equipment?
How can identify it is hardware issue not firmware?
Thanks
Hany
« Reply #4 on: February 11, 2015, 08:25:10 pm »
it was PSU.
Can i get the PSU from other vendors?
i searched online but no luck
Offline tautech
« Reply #5 on: February 11, 2015, 10:12:28 pm »
it was PSU.
So it was not to spec, right?
Which rail was out of spec or was it too much ripple?
How long had ithe scope been sitting unused?
Offline Hugoneus
    • The Signal Path Video Blog
« Reply #6 on: February 12, 2015, 03:29:49 am »
Can you post a photo of the PSU? I am sure it can be repaired.
Offline Hydrawerk
« Reply #7 on: February 12, 2015, 07:58:42 pm »
« Reply #8 on: August 28, 2020, 09:19:26 pm »
I was wrong it is not PSU, I replaced PSU by a new one from tektronix and i replaced display module by a new one.
Now i am doubting it is main board or some in firm ware presenting the system from booting, any ideas. I exhausted all my ideas.
I appreciate your ideas.
