Author Topic: Continuity test with Fluke TL224  (Read 1846 times)
Offline PowerNetTopic starter
« on: May 26, 2017, 03:12:46 am »
Hi all,
So I got my TLK-225 kit and in it is the Silicon Fluke TL224 leads, which no dout a must have.
The issue is with the continuity test, I can get it to fail most of the time.
I have tested it with the standard lead that came with the 87V and works every time.
Has anyone else experienced this issue ?
Im using the TL224 lead with the TP175 probes.
Thanks
Offline BMack
Re: Continuity test with Fluke TL224
« Reply #1 on: May 26, 2017, 05:02:04 am »
I don't have that problem with my TL224s, I have several pairs of those leads as backups and have tested all. I use the TP2 and TL224s with my 87Vs. I have a set of the TP175 at work I can test.
Offline retiredcaps
« Reply #2 on: May 26, 2017, 05:07:14 am »
You should be able to narrow down if one of the test leads/connectors is broken or not with another pair of good ones by mixing and matching everything.
The following users thanked this post: PowerNet
