Author Topic: Agilent 34401A input terminal  (Read 3293 times)
Offline pgrossTopic starter
« on: September 27, 2013, 09:45:41 am »
Hey forum,
I discovered that the input terminal plastic of my Agilent 34401A multimeter is cracked at
the V, Ohms jack. The electrical connection is fine, but the copper terminal is loose, and
when I opened the instrument some small red cracked plastic parts fell off.
Does anybody know if it’s possible to replace the plastic block alone, without desoldering
the terminal off the board?
The Agilent part number (34401-62121) is a complete terminal assembly. But as far as I can
see, the block itself is a sandwich construction with two molded plastic halves fitted together
over the copper terminals. The plastic seems to be brittle - it puzzles me, because the meter
is only six years old!   :palm:
I’ll appreciate any help.
Best Regards
Peter
Up & running!
Offline babysitter
  • pushing silicon at work
Re: Agilent 34401A input terminal
« Reply #1 on: September 30, 2013, 08:43:23 am »
... sounds like the front fell off!  ;)
I'm not a feature, I'm a bug! ARC DG3HDA
« Reply #2 on: September 30, 2013, 01:02:06 pm »
Ahh, well no drama at all  :-DD
But the outer parts of the V, Ohms is cracked and the copper terminal is loose.
I have ordered a new terminal block from Agilent. It should be possible to remove the outer plastic part - without desoldering.
Regards
Peter
Up & running!
