Long time EEV viewer, anonymous forum browser, first time poster. Bit lost on how to figure this.
I've just gotten myself a "new" Tektronix 455 CRO, but CH1 is having a bit of a connection issue.
I've got the probes from the DS1054z and a Tek P6105, and it happens with both of them.
Connect the BNC and nothing shows on screen, but if you give it just a tiny bit of pressure the connectors seems to meet and the calibration waveform will appear.
Tried a wee bit of isopropyl on a q-tip, but didn't really go crazy. Poured over the manual PDF but didn't see much if anything about this particular issue. I reckon it's the central pin, but I'm not super sure how to approach that from here.
I did also notice the Rigol probes seem to stretch quite a bit when attaching, just to get the full connection, but this still isn't enough.
CH2, no issues, works perfectly.
Any help is greatly appreciated. I find this to be quite an intriguing scope, would like to return it to full function.
