Yokogawa and HP partnered together in the mid 1960s and sold each other's equipment.
I think you are probably understating the nature of the relationship between these two companies. The project lead for the 4328A(milliohmmeter) and 4329A(high resistance meter) was named Yoshihisa Kameoka. He was a YEW employee who joined YHP after it was formed.
I've seen this YHP badge on a few Yokogawa designed/made HP products, the boards are usually labelled YHP too.
Given that this might be the only 4320A out there, could you please add some internal pictures.
Hi David, I have a few items with that badge on the front. As far as I know that badge meant it was destined for the Japanese domestic market. The devices I have with that badge are wired for 100v or 100/200 switchable. US bound YHP devices stripped away the Yokogawa designation, except perhaps on the serial number plate and had 115v or 115/230 switchable. I don't think this 4320a is the only example left of this device but I doubt it was sold in the US.
And all this in AC. Does it humm when in use (then there could be a mechanical chopper)?
Can you make pictures of the inside or make a reengineering of the schematic?
Hi Roland, I do not know how it works. A chopper was exactly what I was thinking of when I said a DC milliohmmeter would not be trivial to design with similar constraints(time period, 6V total battery voltage). I do not think it would be necessary for ac amplification, but I am not an expert.
I didn't expect anybody to show any interest, this is a nice surprise. I took a few pictures and made some observations. Batteries corroded and made the inside dusty even though the batteries are in a nice separate compartment. It takes 4x D batteries, earlier I couldn't remember if it was C or D. A previous owner drew the orientation for the batteries in pencil inside the compartment (thank you!). I haven't put any effort into cleaning it or making these images look nice, sorry.
I don't know what the 4 large metallic cans are. They are sequentially numbered in HP part no. style (04320-xxxxx) there are 8 terminals and 2 larger screw terminals for mounting with what looks like insulating washers. I think I counted 12 transistors, 4 are on one pcb and are Toshiba 2sb200's I believe. There are 8 transistors on the other side, the few I looked up were Toshiba 2SB germanium transistors. Some of the transistors and diodes look like capacitors due to old packaging. There appear to be 2 transformers and a choke all of similar size. There is one potentiometer on a PCB, the only other potentiometer I saw was the front panel current set. There are quite a few 10v/15v electrolytic caps that look fairly anachronistic, but I am not an expert on capacitors. There are several diodes on the PCBs and also on a small detector(?) pcb mounted on the front panel. The detector(?) pcb has 4 diodes that look like the old top hat style as well as a wire-wound resistor. The toggle switch next to the potential cable seems to just open that connection at the cable. It doesn't seem like the alligator clips that are installed are true kelvin, but there are 2 wires going to the base of each alligator clip at least.
