Calin
Yes, the old Tek scopes had something special to them as well. Too bad, those days are over.
In regards to the Fluke 8842A, I had two of them in the past and they could not width stand, being in the near of high voltage measurements. Even when they were not hooked up to anything, the radiated noise from a spark discharge got them completely screwed up. I had the same problem with the really nice Philips Multimeter, the PM2535. Since I am doing a lot of high voltage measurements, I could not really use either of them. Interestingly, the Agilent 34401A can even be hooked up to the circuit that is producing the high voltage and it keeps measuring perfectly. I never had a Agilent 34401A fail on me with this kind of measurements. The same is true for the Leader scopes, they just work and work.
