Author Topic: Home lab setup : what I have in mind  (Read 2314 times)
Offline uskiTopic starter
« on: October 17, 2020, 09:09:51 am »
So, I stopped doing electronics at work (new career)... now I have to build a lab at home, because I can no longer access any equipment :scared:
I wanted to share with you the setup I have in mind, for discussion and also if it can inspire others with a similar need.
I tried to balance price, features, quality, and "upgradability".
Here is what I have in mind for the equipment. Not a lot of space. I want the good stuff.
  • Rigol MSO5074 as the scope (with a bandwidth/options "upgrade" ;))
  • Keithley DMM6500 as the multimeter (pricey but these things seem to last decade, so better invest now and enjoy it for a long time)
  • I have a NanoVNA V2 (S-A-A-2) as a VNA, but if I end up doing a lot of RF stuff : Siglent SSA3021-X Plus (with a VNA "upgrade A/B" ;))
  • I also have a Philips PM6665 frequency counter
  • And I will rebuild myself a GPSDO like I described in this post
Planning to keep the DMM6500 calibrated as a voltage reference, and the GPSDO with its OCXO will be the timing reference. I might get a DMMCheck Plus but it's overkill, maybe a cheap eBay AD584 reference will do the trick.
I will also get a Hakko FX-951. I considered the AliExpress clones but between safety and reliability issues... no thanks.
Planning to use the Saelig discount (too bad they don't have Keithley/Tek equipment).
PS: manufacturers, if you are reading, don't close the upgradability path. It is the reason I am buying this setup. Otherwise I would get older used equipment.
Any idea/suggestion/remark ? I think this provides the best "bang for the buck" for new equipment.
« Last Edit: October 17, 2020, 09:13:29 am by uski »
The following users thanked this post: gdombi
Offline MarkF
Re: Home lab setup : what I have in mind
« Reply #1 on: October 17, 2020, 09:28:53 am »
tEquipment  has Tek equipment with the same EEVblog discount.
The following users thanked this post: uski
« Reply #2 on: October 18, 2020, 02:28:37 am »
Hey awesome ! Thanks
I found the code here :)
[EDIT] Hmmm they don't seem to carry the Keithley (Tek) multimeters ! Bummer  |O
Online J-R
« Reply #3 on: October 18, 2020, 03:31:35 am »
I think the DMMCheck Plus with the capacitance board is a good deal all around.  Definitely not overkill.  Given the equipment listed, it would be great for sanity checks.
Offline JimKnopf
« Reply #4 on: October 18, 2020, 01:16:35 pm »
I can recommend the Atten ST-862D Hotair Station and for microsoldering the JBC CD 2SQE.
The DMM6500 is a very nice and precise device . The limitation in measuring capacitance only up to 120µF is anoying.
If the much expensive DMM7510 is not an option, you need an additional tool. I bought the DER EE DE-5000 for that.
The benefit is the ESR and Henry measurement.
« Last Edit: October 18, 2020, 01:19:06 pm by JimKnopf »
The following users thanked this post: lukego
Offline Elasia
« Reply #5 on: October 18, 2020, 04:16:34 pm »
I thought about a Keithly DMM but ended up with a siglent unit with scanner card for 1100 total vs 1800 for keithly with scan card, the siglent works pretty good, been happy with it
« Reply #6 on: October 19, 2020, 04:52:57 am »
Thanks all.
The reason I like the DMM6500 is that it goes up to 1MS/s which is pretty awesome.
This video :
...removed the Siglent units as an option for me : they are slow, unpolished, and behave strangely in auto range, in my opinion. DMM6500 looks so much better in all aspects.
DMM7510 is definitely not an option, cannot justify it for home use. If it was for work, I would probably consider one. Regarding the scan card, for now I don't feel the need for more channels.
In general, seeing the high resale value of 30+ years old units, I don't feel like purchasing a new multimeter is crazy.
Thanks for the info about the limit for capacitance measurement, I did not notice it. I used to have the DER EE DE-5000 at work before, cool unit, you are right, I might get one.
But I do have a GM328A on order, I plan to flash it with the firmware described here and I hope its performance will make it a useful tool, if not the most precise one.
Quick note for the MSO5074 MSO capabilities : a fellow inmate is selling cheap probes which I may get.
JBC CD 2SQE looks awesome, but probably above my price point. The Atten ST-862D however is okay pricewise, but it is difficult to compete with the price of a AT-858D and its clones :
Considering I will have a very occasional use. I also like that they are smaller (space is an issue). I am however concerned about the safety of these (uncontrolled supply, many clones everywhere) :
I also have a Flir E30bx that somehow became a E60. It is incredibly sensitive and a very useful tool (I used it to diagnose a power loss of around 1mA @ 12V, I could see the 0603 resistor dissipating it glow).
PS: Putting some efforts to put some links, to helps the newbies that might come around here
Offline JimKnopf
« Reply #7 on: October 19, 2020, 06:40:44 am »
Yes indeed, the price for a 858 clone is very low. But also the quality is very low. I recommend increasing fire insurance when using an 858 clone.
I used a cheap ZD-912 combo soldering station for more than 10 years until i despaired of a board that absorbs more heat than this soldering station could do.
I gave a 858D clone a try. I only heated them up once and quickly repacked and sold them.
My risk appetite and the quality of this hotair station did not match. I then bought the ST-862D and i'm very happy with it. That is a very different quality level.
My thermal camera is a CAT S60 phone which has a FLIR sensor. Not the best one but good enough for my needs and cheap (200 Euro by second hand). The benefit is, it needs very few space.
« Last Edit: October 19, 2020, 06:44:25 am by JimKnopf »
