(I hope this is the right forum for this post).
First a bit of background:
I'm an electronics newbie - no formal training, all self taught. I've been dabbling a little, but have only started to get serious in my hobby in the last couple of months. My first original scope was a Dick Smith special (Q1803 10Mhz 1Ch) which when I first bought on eBay about 12 months ago (<$50 from memory). I knew it was limited in what it could do, and at the time I just couldn't find a higher bandwidth scope for a cheap price. I just wanted to play with a scope and see what it could do with it. At the time I thought "I wouldn't need anything faster than 10Mhz because I'm only playing with 1Mhz signals" (This is before I knew what the bandwidth meant). "I'm playing with digital arena anyway". I tried to use it a couple of times, but I couldn't really get any meaningful information out of it (I could get nothing new than my multi-meter would give me). I then stuck it on a shelf and it collected dust. Scopes are useless to me.
I.. was.. so.. so.. wrong..
Last week, after getting a little frustrated why some of my circuit ideas weren't working as I expected, I decided to find a better scope - I came across a dual channel Hitachi V 1656 2Ch 100Mhz scope on eBay (around $80) and figured I can't afford a fancy Rigol DSO scope, I'll try and grab this and see what the fuss is about.
I was a little worried that maybe it wouldn't work. For $80 surely something would be broken, a dial missing, etc.. The scope came with no probes or power cables, but after playing with all the settings on the scope and trying different things to test each setting (I used my 60Mhz probe from my Q1803 - so hopefully that will be ok still), everything appears to be working - Bonza!! It even has a calibration sticker on the side.
This beast has so many features that my little Q1803 didn't have. I'm going to have to learn some of these extra functions (like the delay and hold-off settings).
I just wanted to say that Dave's video (#86) on "Get an analog scope for under $50" still rings true today (ok, add a little for inflation - its a 5 year old video). I don't know if I just got lucky, or maybe $80 is way too much. Either way I've just spent the past few hours just playing with the scope and actually saying out loud 'wow' when I can see the extra ringing on my 1Mhz square wave which my old scope didn't show. It also shows my clock signal 'echoing' into a ground signal. None of this I could see with my old Q1803. I can already see a new world so I've already got my money's worth!
Because I have 2 channels now, do I need to use a 100Mhz probe on a 100Mhz scope? I assuming that I already have a 60Mhz probe from my Q1803 the scope's bandwidth would be limited to that. To get the full 100Mhz I need a 100Mhz or greater probe?
And while I'm on getting another probe - how does the ext-trigger connected up? Is that just another probe connected to it?
