Author Topic: History of Tachikawa (TMK)  (Read 14894 times)
Offline joeqsmithTopic starter
« on: October 07, 2017, 03:15:00 pm »
I was given an old Tachikawa meter and had never heard of the brand.  So I attempted to do some research on them but found pretty much nothing.   This meter was rebranded for IBM and is the 200C.  They seem fairly common on eBay and I would doubt are collectible or have much value.
This link shows a SN starting with a 6,5 or 9.  Obviously they produced a fair number of them.
http://www.ebay.com/itm/IBM-Model-200C-Analog-AC-DC-Volt-Ohm-Meter-Read-below-/253158141785?hash=item3af166af59:g:OqYAAOSwpuBZve3B
I wrote the IMB archives to see if they had any information about why IBM had the meter built.  So far I have not heard anything back from them.   A friend of mine wondered if they were not some employee handout sort of thing.
Does anyone have any history on TMK or how IBM got tied in with them?   I'm sure there is some story there.
The following users thanked this post: Bud
Offline coppice
Re: History of Tachikawa (TMK)
« Reply #1 on: October 07, 2017, 03:21:01 pm »
TMK meters were pretty common in the late 60s/early 70s. They were excellent quality, so its not surprising IBM would have used them as a source for their own meters. The one in your picture looks it was designed specifically for IBM, as TMK branded meters generally had 2mm sockets. Your picture seems to show 4mm sockets.
« Reply #2 on: October 07, 2017, 04:32:55 pm »
To be clear, the ad in the ebay link is not mine.  Nor am I trying to sell mine.  It was only for a reference.
From the internet it appears they were also known as:
Tachikawa Radio Instrument Co of Japan
Tachikawa Radio Measurement Co
TMK, Tachikawa Radio; Miyatani
TMK is the abreviation of Tachikawa Musen Keiki.
Musen is the old Japanese word for 'radio'.  Keiki is business.
I also found a few ads and a schematics.  Nothing matched.  The one attached is for an AMK-200.  Similar, sort of.  Like how a cow would compare with a dog.
Funny, I don't think of IBM as a hand held meter supplier for the public.  This is why I wonder if it was made for their employees.  Possibly for their field technicians.
« Reply #3 on: October 07, 2017, 04:42:57 pm »
I had also found this picture showing what appears to be SN# R201356.  Note there is no fuse holder and the two additional, unmarked jacks.   Maybe IBM told them that a fuse may be a nice thing to add after a few mishaps.    I'm sure there's some stories here.
Offline coppice
« Reply #4 on: October 08, 2017, 12:04:42 am »
Musen is the current word for radio, or more accurately wireless, too. Mu == ? == haven't. Sen == ? == line. Its the same term used in Chinese.
You are probably right. They might have been for inclusion in customer toolkits, or something like that, but I don't think they would have been sold as a standalone product.
« Reply #5 on: October 08, 2017, 03:01:58 am »
Here's the IBM branded 200C I have been working on.
https://youtu.be/2H6YKvnOQyw
The following users thanked this post: SeanB, Bud
« Reply #6 on: October 08, 2017, 08:27:30 am »
I have had plenty of AAA NimH cells leak, though generally they only do so with prolonged overcharge. Resistance ranges say the lead and switch resistance is around 2R, and as well you really do need to measure over half scale on resistance, as the accuracy below half scale will be slightly off. AC voltage scales were always different, simply because of the diode drop in the meter measuring circuit, and those with an "output" input had to have a half bridge, often also recycled as the DC meter movement protection, to make sure there would be current flow on both half cycles so the capacitor would not charge up. Also remember the accuracy specs on all ranges were with the meter at close to full deflection, and the error would be roughly the same all through the movement range, being typically 2% plus reading errors without a mirror scale.
« Reply #7 on: October 08, 2017, 03:52:03 pm »
I have yet to see a NiMH leak.   I have some in my phones that must be close to ten years old now.  The most I saw from one that fail was a small amount of powder (from a phone).  Nothing like the damage I've seen with some of the Alkaline's that have leaked on me.
As I stated, there were no accuracy specs that I was able to find.   Not that it matters.
If you looked closely at the check sheet for the meter,  the 1.5VDC range was checked it at five different levels.  I assume this was done first to verify the linearity.   After this, the AC/DC voltages and DC current ranges were all checked at full scale.   If you look at the resistance, they ran through all the ranges at 20.  Not quite center scale.   Again, no accuracy specs but we do know they did not test the meter at full deflection in all modes.
If you looked at the schematic, you noticed the separate clamp to protect the meter.  I would assume they compensate for the diode drops for the AC mode.  Also, there is no capacitor in this meter (not an actual component anyway).
« Reply #8 on: October 08, 2017, 07:11:28 pm »
I would show you the ones I scrapped this week, but they went to the scrap steel pile, and I am not digging through the drum to find them, way too much sharp stuff in there. Linearity on those meters is entirely dependant on the meter movement, and with the right pole piece design and the right magnetics in there you get pretty much around 0.5% accuracy on most Japanese meter movements, depending on manufacturer, but some cheap ones were only specced to 2%. I have a Hioki meter, which claims 2%, and which uses 1% resistors inside, though almost all the resistors are not E96 values but specific to the meter. Resistance was always going to be the poor side, as you really need a precision voltage source, which an AA cell is not. Better meters ( like light meters as well) used a mercury cell in there, as it has a very flat voltage curve, which gives the error you see as the cell ages, your new AAA cell might be slightly over 1V5, and as it ages it will drop, giving a slight error. In most cases analogue meter resistance readings were good for 5% resistors, any better and you went to another method, like a proper Wheatstone bridge, which was not dependant on the battery voltage, but only needed accurate resistor ratios to be accurate.
« Reply #9 on: October 08, 2017, 09:00:31 pm »
To be clear, I was not asking to see your leaking cells.  If you damaged several from over charging them and fail to learn not to do that, I really have nothing to learn from seeing the end result.  I use a proper charger and can only tell you that I have yet to see a problem with them.   Maybe there is a lesson one of us could learn from?
I really have not used an analog meter in many years.  Since my youth.  If I had a top of the line one sitting here, it would get used as much as an analog scope.   When I was using one, I would guess 10% for my amature skills was more than enough.
« Reply #10 on: October 12, 2017, 12:16:37 am »
The new Panasonic batteries came in today.   I had this meter all apart and the nut for the selector switch was originally held in place with some off white paint.  So I touched that up and painted the tops of my custom sleeves.  The batteries are worth more than the meter.
I spoke with my wife's brother who had found the meter.  He was surprised I tried to restore it.  As I understand it, it was found in the basement of an abandoned home.  The home was starting to collapse and this is why they were brought in to demo it.  They will normally do a walk thru to check for any hazards and this is when he saw the meter in the basement.  The women who owned the home had passed away in her 90's.  She had never been married and never held a technical position.  How she ended up with the meter is a mystery.
I never heard anything from the IBM archives, so I am at a dead end.
The solder work you see is for the most part original.  I was trying to preserve the meter as much as possible.  I didn't mention it in the video but to repair the corner, I used some mylar tape that I basically formed a dam around the inside and outside of the case, after I had prep'ed the plastic.  I then filled this with epoxy and let it set.  Once the tape was removed, I had the basic shape.  Lots of sanding and buffing after that.   I had looked for some old plastic and was going to make a powder to blend in with the epoxy to help color it.   I could not find anything laying around to salvage so I just used three different colored markers to get it somewhat close.
« Reply #11 on: October 14, 2017, 03:57:41 pm »
I received a response back from the IBM archives and sadly they had no information on this meter.  They copied their curator.  I provided them with a link to the video.
The white Panasonic batteries look alright with the white sleeves.
« Reply #12 on: October 15, 2017, 04:49:16 pm »
Not my charger, but the ones built into Siemens Gigaset cordless phones, All of them from the earliest version ( at least from 1990 when we started using some variants of them) do not have good charge termination, and will charge the cells continuously. While a NiCd cell will be quite happy with this charge NimH cells tend to generate overpressure and fail after a year or so, so for those phones that are placed every night to charge they kill the cells in around 9 months, and I have to buy a new set of them. Makes no difference as to what cells I put in, even the original ones die in that time, and I just keep my phone off the charger all the time, placing it on for around an hour every 3 days or so to charge.
Other than that they are somewhat reasonable cordless phones, though I do really miss the old Panasonic KX-P9080 I used to use, even with all the issues it had with really poor flip design, it at least had a 1km range. I kept it going thanks to having a good supply of water and other damaged KX-P 9001 phones to rob case parts, speakers and microphones from, though I gave up eventually on the flap and put in a small switch to act as hook switch, along with making my own antennas for it out of old bits of coax cable. Eventually ran out of spares and RF modules for it though, though the 4 AA cells in the batteries were easy to repack, I just put in high capacity cells, and that rarely gave trouble.
« Reply #13 on: October 15, 2017, 05:41:08 pm »
2017 to 1990 would be 26 years or 324 month or 36 sets of batteries.  At some point, it would seem ditching the phone would make sense.  Even ditching the OEM charger, buying a separate charger and rotate batteries may have been more cost effective.
Last Friday, I installed new NiMH batteries in the neighbors cordless phones.  Three handsets with 3 AAA batteries ea.  The old ones are marked Panasonic but made in China.   There are no date codes from what I could tell but I expect the phone was well over 5 years old and there are no signs of any leaks.
I still use my old Olympus Camedia BA-100 charger along with the original batteries.  These have a date code of 00-11.  Maybe Nov of 2000.  It would be close to the age of the camera.  Like the ones I use now, they reached a point where they would not hold a charge but 17 years without a leak seems pretty good.    That's a pretty low end charger.
« Reply #14 on: October 16, 2017, 04:43:46 pm »
I received a response back from the IBM archives and sadly they had no information on this meter.  They copied their curator.  ..
I received an email from the Curator Of IBM Artifacts
... I started with IBM in November 1966.  At that time  I was a field repair person for the Office Products. In My tool bag I was issued a similar meter.
And that's all the information I can add to your  meter research. ...
At least it tells us that IBM did supply meters to their service departments and our little meter may have been built for internal use but how this particular one ended up in the basement of an unmarried lady who did not work in tech, we may never know.
Online Bud
« Reply #15 on: October 16, 2017, 05:02:32 pm »
I wonder what office products IBM was making in 1966...maybe that could give someclues.
Offline fanOfeeDIY
  • Country: jp
    • YouTube Channel
« Reply #16 on: October 20, 2017, 09:46:48 am »
I have the meter!
What a consistence.
My father used to be an IBM Japan employee started as a type writer engineer, since he was mechanical engineer.
The company grew in electronic and computer industries, while he was keep being a mechanical engineer.
Already retired long time ago.
The 200C analog multimeter was in his type writer service case with other tools like screw drivers and etc.
And I borrowed it when I was in high school from his service bag :) and still keeping it.
The multimeter seems to be slight different revision since it uses regular AAA battery.
The solder joints are still very good and I uses this meter for battery checker some time,
because analog meter draws current and it is easier to hunch the battery life
by watching the speed of needle movements.
I attached the pictures of mine.
This was *the* first multi-meter for me and I really took good care of it until today.
The leather case and leads are genuine. I could assure that.
« Last Edit: October 20, 2017, 09:48:19 am by fanOfeeDIY »
Offline fanOfeeDIY
  • Country: jp
    • YouTube Channel
« Reply #17 on: October 20, 2017, 09:50:24 am »
Musen is still uses nowadays as wireless, and keiki means measurement tool.
blueskull is right. The word of "keiki" used for any equipment looks mechanical and have a meter.
« Last Edit: October 20, 2017, 11:35:36 am by fanOfeeDIY »
« Reply #18 on: October 21, 2017, 06:04:47 pm »
I have the meter!
What a consistence.
Thanks for the response.  Looks like the serial number is 7129031.  Would seem to be a newer meter than the one I was given.  It would make sense that if they were having troubles with US batteries, they may have changed the case dimensions.
What I find VERY interesting with your dads old meter is that the resistor circled on yours is attached to the meter (-).   If you look at mine, you will see it also attached to this same location but has some black sleeve over it.  This resistor  used to go to the fuse holder but I added the sleeve and changed how it was wired.
On your meter, when you remove the fuse, can the meter read both current and voltage resistance?  I wonder if they actually changed the design like I show in later serial numbers.
Wrong mode.  Actually, it would be good to how the fuse effects all of the modes on your dads.
« Last Edit: October 22, 2017, 04:41:45 pm by joeqsmith »
« Reply #19 on: October 22, 2017, 01:41:35 am »
The Selectric typewriters?
Online Bud
« Reply #20 on: October 22, 2017, 04:38:17 am »
Ok so how about a story with a IBM office products repair technician coming to the lady's house to fix her typewryter, then forgetting the meter there as he leaves the house.
« Reply #21 on: October 22, 2017, 04:39:31 pm »
I'm sure you could make up all sorts of stories. I doubt an IBM service person would make a house call to repair a personal typewriter.  It would make more sense they would send the typewrite to a repair shop.
I was able to find out a little more about the lady who owned the home where this meter was found.  She apparently owned several properties in the area and would rent them out.  I also understand she was a hoarder.  It would make sense that the meter was owned by someone renting from her and it was left behind where she added it to her collection.   That's the story I am going with anyway.
Offline fanOfeeDIY
  • Country: jp
    • YouTube Channel
« Reply #22 on: November 07, 2017, 11:35:00 am »
Sorry for the late response. I was busy with my hobby project making a flight controller of a drone. :)
I tried removing the fuse from my meter and I was able to measure voltage and current but not the resistance.
And I searched for the size of AA battery standard in Japan (it is called JIS) and found that the minimum length was 49mm and maximum was 50.5mm, so some batteries were only targeting 49mm. The 1.5mm difference is a lot for only 50mm battery.
I heard that now all are 50.5mm in Japan.
And this seemed to cause some batteries do not fit in the battery case. :)
Offline fanOfeeDIY
  • Country: jp
    • YouTube Channel
« Reply #23 on: November 07, 2017, 11:55:51 am »
Another point that I found today when I was testing the meter, the accuracy for the resistance and voltage were very good but not so well on the current range any more.
Well it must be made in 70' and not
And the leads I have is probably not the original one. It looks like I made them more than 30 years ago with 2mm banana jack with slim pvc cable with alligator clips.
I think I wanted to have the alligator clip to my meter.
« Last Edit: November 07, 2017, 02:02:59 pm by fanOfeeDIY »
« Reply #24 on: November 07, 2017, 01:31:13 pm »
Thank you for taking the time to check.  I would have bet on it protecting the current input.  It's strange how they would change how it was wired but maintain the same functionality.   I wonder if this change was a labor savings.
I saw another one that was also newer than mine.  On mine, there is a white plastic part that bolts in behind the clear lens for the movement.  On this meter, they were no longer making this plastic part but instead using paint.  I assume this was for cost as well.
I suspect that the alligator clips on mine are also not original.   The banana connectors and wire appear correct.  Everyone I have seen for sale appear to have the leads altered.
This one showed up with an older SN but the leads appear to be newer.
https://www.ebay.com/itm/Vintage-Tachikawa-Model-200C-IBM-Voltage-Ohm-Meter-Works-great/322866105225?hash=item4b2c51cb89:g:e1IAAOSwPAxZ~4GV
