Author Topic: Rohde & Schwarz FSIQ26 ........ well almost  (Read 4253 times)
Offline Kilo TangoTopic starter
« on: October 27, 2017, 01:23:34 pm »
When buying test equipment, it is wise to stick to well known makes, because when there’s plenty around there is usually plenty information about how to keep them running.
Less well known makes suffer from lack of technical/repair information and lack of availability of spares. Even worse is units with parts missing, because you might not know bits are missing until later, you may not know what they are and lastly not know part numbers or even what they look like.
So…..
I recently bought the Rohde & Schwarz FSIQ26 ( bits missing ) analyser that had been on Ebay for quite a while. It was on 24hr delivery, so I checked tracking info, yes it  had arrived at the local depot and was due for delivery the next day, so I waited in all day but nothing arrived. I waited in the next day and nothing arrived. I waited in the next day, still nothing arrived. I contacted the seller on the monday, she said she would contact the courier and get back to me. I also emailed the courier, their reply was basically “very sorry, tough, don’t contact us again, go thro the seller”. After 2 weeks nothing had been heard and the seller had refunded my payment, so in a last ditch attempt I wrote to the local shipping depot and the world wide operation’s director asking them to try and find it  AND enclosing photos of what it looked like. A couple of days later I got a phone call saying the shipping label had come off but they identified it by my pictures. So after a 24hr delivery that stretched out to 3 weeks it finally arrived.
There was some service info available, the FSE manual which the FSIQ appears to be derived from, but there were several differences that lead to later confusion.
When it arrived I started by looking it over, checking for missing bits and loose wires. At first glance there was a gap where the attenuator should be, but I knew that from the auction pics, and there were a couple of R & S attenuators on Ebay so hopefully that shouldn’t be a problem. The vector analysis board was missing but that seemed to be all.
However there were 7 off RG316 cables cut thro, the floppy and attenuator ribbon cables had been cut in several places and a couple more power lines chopped. Also the rigid cable to the front panel input had been ripped out. Strange. The chassis rails and middle case support on the RHS were also missing.
Initial power up revealed a noisy hard drive so I shut down and backed this up. A bit of research suggests that if you try and back up using a windows machine, it will overwrite parts of the drive, however there is a Linux HD backup program called DDrescue which is supposed to be very good and does a byte for byte copy. As I had several to do, I put together a Linux machine, using an old Athlon 64X2 PC and loaded Linux Mint 18. This loaded very quickly, about 10mins in total.
I then tried to install DDrescue, but not being experienced in Linux systems, I couldn’t get this to install, however I came across a GUI version that installed perfectly and was very easy to drive. I backed up the HD onto a 4 G CF card and fitted it into a cheap and cheerful CF to IDE adaptor. Insulated off the metalwork and held in place with hot glue, this worked absolutely fine, and the FSIQ booted up.
It stopped at “enabling resources”, after some investigation, the problem was tied down to one of the Transputer cards, so I pulled the faulty one off the video card and it ran up to the analyser screen.
I repaired/replaced all the cut RF cables and it worked, a bit noisy but success !. I replaced the temporary input cable with a semi-rigid and noise level went way down.
Hang on its supposed to be 26GHz but input to the RF converter is SMA which is only good for about 18GHz and there is an unused MW converter module with an unconnected SMK socket in the vicinity ?. The FSE manual had no information about this, it only covered the 3.5GHz model,  but a very helpful person at R & S ( thanks Stephanie ) passed on information about what should be there. It appears that as well as cutting all the cables, pulling out the 2 chassis rails and removing the input attenuator, someone has removed the diplexer that splits the input signal and routes up to 7GHz to the first converter and higher frequencies to the MW converter. A YIG filter and 1dB attenuator were also missing.
A search for case bits was unsuccessful, so I made a couple of chassis rails.  I might be able to make a case for it, but trying to bend large sheets of aluminium without a proper shear and folder is a pain. All the R & S attenuators on fleabay are too low in frequency; I am currently using a couple of 10dB attenuators plugged into the front, and am looking at decoding the switching signals to drive an HP attenuator. I haven’t seen a diplexer or YIG filter yet.
Close but no cigar ?. It falls short of being the full 26 GHz and “only” does up to 7GHz, however that is still pretty useful ( above a Rigol ! ) and above my other kit. Its a pretty impressive machine and has lots of functions and facilities. The UI will take a bit of getting used to but all the professional stuff has a learning curve to get the most out of it.
I am curious as to why any sane person would rip a working analyser like this to bits and cut all the cables. Its as if they didn’t want it to work again ?.
                                            Curious, another of life’s mysteries.
Ken
« Last Edit: October 27, 2017, 01:27:37 pm by Kilo Tango »
Offline MindBender
Re: Rohde & Schwarz FSIQ26 ........ well almost
« Reply #1 on: April 03, 2018, 08:24:26 am »
I own a fully functional FSIQ3, in need of a new battery. I will open it up soon to replace the battery, so if you need any pictures of it's internals, please let me know.
Offline DaJMasta
    • medpants.com
« Reply #2 on: April 03, 2018, 04:09:42 pm »
The fact that you could get something to boot and show from such a butchered corpse of an instrument is pretty good...  :-+
As for the SMAs and their frequency rating, they're probably 3.5mm connectors, which look effectively the same but are good to 34GHz or so.  If you had to replace those cables, it may be worth getting proper non-sma replacements, but I'd expect the connectors themselves to be the better variety if the stuff they're attached to is rated to 26.5GHz.
I feel like for this sort of instrument, the best way to get replacement parts is to buy a second broken one.  Not really cost effective in a lot of cases, but you could try selling the remainder of the bits again, and it could be quite a wait for proper replacements.  Maybe it's worth looking into how the attenuator is driven (data interface), because it could be that a different brand could be made to work with a custom mount, since it's typically a very simple interface to actually drive the solenoid logic.
Offline Marflow5
« Reply #3 on: April 01, 2019, 10:39:42 pm »
Hi Kilo Tango,
thank you for the desciption of your FSIQ26 issue. Hope it still does a good job for you. I am a german radio amateur and had luck in getting a FSIQ26 for my microwave measurements.
Howerver there is a drawback. Not cutted cables as worse as with yours, but also not working. Booting is not completed because of a faulty HD - making a lot of noise and not reaching its full speed. Hardware itself seems to be complete, that´s great! So far my description.
Without external help I will not be able to my device working. Therefore I would like to ask you if it would be possible for you to provide me a copy of your Harddisk content so that i can get a booting system here again? I also would like to take the opportunity to modify to CF-card with CF-IDE interface and replacing the HD. But without the NT boot information all this will not work. My FSIQ26 is version 26, as yours (and not 27), Bios-Rev. 3.3, but I think newer versions will work as well.
Would be happy to listen from you and hoping to get my unit working with your help.
Marflow
Offline Extrasolar
  • Country: ie
« Reply #4 on: July 03, 2021, 04:30:03 pm »
Hi Kilo Tango,
Is it possible to get a copy of you HDD image ?? I have installed some options on my FSEM30 that actually did remove some functionalities and now i cannot complete CAL TOTAL, it seems that the cal data does not save !!
There is an EMI Receiver MODE that is messing with everything and I need to uninstall it.
