Author Topic: Used $100-200 Bench DMM ?  (Read 4745 times)
Offline David Hess
  • DavidH
Re: Used $100-200 Bench DMM ?
« Reply #25 on: July 15, 2018, 07:28:56 pm »
I went with a Keithley 177 for $80 total. It powers on but not tested.
It's 4.5 digit, and has 20u division, compared to 200u on pretty much all the other ones that price.
I used to see a lot of Keithley 177s used with strain gauge bridges because of its 20 millivolt range.  I think HP had a similar 4-1/2 digit meter with a 20 millivolt range.
The Keithley 177 has full documentation and used standard parts so it should be very repairable and calibration does not require anything special.
Offline lordvader88Topic starter
« Reply #26 on: July 15, 2018, 11:20:35 pm »
Ahhh 20uA and 20mV, thought it was 20uV. But  yeah most other sub $150 ones are 200mV
And it's a lot more repairable then the $200 HP/Flukes. And I Had money left over to order some more oscilloscope probes, a multi-set of DMM probes, a 300W power resistor, etc.
I have a Mastech 5308 LCR meter with Kelvin probes. No idea what it's resolution or accuracy is or is supposed to be. But so I do have something with Kelvin probes.
Offline coromonadalix
« Reply #27 on: July 16, 2018, 10:50:33 am »
the 177 seems very nice for its age, not too high tech, schematics available,  tons of switches to clean, but eh   if it works well,  good findings
the 197 seem a good contender too ?? 5 1/2 digit 220,000 counts, supposed to do 1uv up to 1k volts ??
« Last Edit: July 16, 2018, 10:54:06 am by coromonadalix »
Offline coletas
« Reply #28 on: October 12, 2019, 11:26:26 am »
Hi! just relaunching this old topic for sharing this.
Is a GPIB interface built with an arduino mega and a cheap tm1638 display controller for a fluke 8842a (I suppose other DMM's can be adapted easy too). Altough my VFD display is still perfect, I just wanted to have the display in other place and have a continuity beeper.
Since I just built it for personal needs, if anyone needs it, please tell me and I will document the project.
Offline RichardM
« Reply #29 on: October 13, 2019, 10:43:57 am »
Hi, I would be interested in seeing your project documented. Looks interesting.
Richard
