All,
Thinking about picking on of these Rigol DP832 up, and have a question. Since channel 2 and 3 share a common connection, it seems like the DP832 would not be able to be used to power both the analog and digital side of board in that, I couldn't track with channel 1/2 ±15V, then give 5V to the digital side of things with channel 3, correct? I'd have to run channel 3 to a 5V regulator with, at the lowest, 10V?
Basically, could I get away with having just one bench power supply. =P
Thanks!
