An electrician and a power electronics engineer never use the current measuring ranges in high energy circuits.One always uses current clamps.I doubt about the need of such ABS, Automatic Blocking Socket.
LG DM-333
Quote from: TheBay on August 28, 2015, 09:03:43 amLG DM-333I don't think LG makes their own meters. it says patent pending. Did they ever get it?
Here is a Goldstar version:I don't see the 10A jack being blocked. Perhaps the blanking system was slightly different.
Would they use the current ranges in low energy circuits? If yes, the classic mistake is to leave the probes in the current range while trying to measure a high energy voltage later, possibly with dire consequences, hence the blocking system.If they don't use the current ranges at all, there are safer and cheaper meters built without current ranges, alleviating the need for misuse protection.Clamps aren't very accurate in DC mode, especially in the mA/uA range.
Another reason the Hioki meter is expensive is that Gossen holds the patent for the input blanking system (ABS, Automatic Blocking Socket) and Hioki probably has to pay royalties to Gossen. Something Fluke and others are not willing to do.http://patents.justia.com/assignee/gossen-metrawatt-gmbh
Quote from: Wytnucls on August 28, 2015, 09:07:16 amWould they use the current ranges in low energy circuits? If yes, the classic mistake is to leave the probes in the current range while trying to measure a high energy voltage later, possibly with dire consequences, hence the blocking system.If they don't use the current ranges at all, there are safer and cheaper meters built without current ranges, alleviating the need for misuse protection.Clamps aren't very accurate in DC mode, especially in the mA/uA range.In low energy circuits, there is nothing very dangerous to simply burn a fuse...the blocking system does not protect against misuse...you can let your probes on current inputs, your range selector in DC or AC current and try to measure voltage.For measuring low current with a clamp meter, you use 10 turns and you read 10x the current.
To answer the original question... HIOKI DT4282 all the way.
The Brymen has 500.000 counts, while the Hioki has only 60.000 counts, still the Hioki is much more expensive. How come?
Because counts isn't the only thing that goes into coming up with the price.
It depends on what you plan on using the meter for. The Brymen is probably more durable if your meter takes a hit how and then. They are both excellent meters and you would be happy with either one. Personally I would get the Hioki because it's truly a slice of multimeter heaven. Lightning fast stable readings and a flawless build quality. (to me anyways.. )
