Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Products
Test Equipment
Agilent / HP CDMA base station E6380A ; replacing memory batteries.
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Agilent / HP CDMA base station E6380A ; replacing memory batteries. (Read 2074 times)
Palmsquirrell
Contributor
on:
April 08, 2014, 11:51:45 am »
Agilent/HP CDMA Base station E6380A
I get the following : "
AA memory backup batteries are low
I do not have a owner's manual, but I did look at an online manual but have not found the instructions on how to replace the batteries.
Thanks
Logged
Towger
Super Contributor
Country:
Re: Agilent / HP CDMA base station E6380A ; replacing memory batteries.
Reply #1 on:
April 08, 2014, 12:12:02 pm »
You need to improve your google skills.
From page 31 of the manual:
http://www.home.agilent.com/upload/cmc_upload/All/6C06UGE6380-90016.pdf
Do not use rechargeable batteries.
To change the AA batteries, use the following procedure:
1. Turn off power and unplug the Test Set.
2. Remove the six screws in the rear panel using a TX-15 TORX (R)
screwdriver.
3. Remove the rear cover.
4. Replace the AA batteries.
5. Replace and reconnect the rear panel. Dispose of used batteries
properly.
Logged
Palmsquirrell
Contributor
Reply #2 on:
April 08, 2014, 04:20:19 pm »
I looked at that same manual and saw batteries mentioned in the Index as being on page 31. So I went to page 31 on the pdf instead of page 31 on the actual manual.
I normally check the page number printed on the paper as it does not correspond to the page # on the PDF but this time I forgot all about it.
Thanks.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Products
Test Equipment
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
