The only bad side is limited diode range to 1.500V othervise so freaking good!
Amazing LCD display, 500uS continuity mode, fast diode and ohm range, very fast ohm autoranging.
DC range is so fast without settling down problems. Bargraph 40 times per second.
Quality is very good, selector switch uses similar mechanism as Fluke 87 and has very similar felling, however, their older models used way better mechanism with metal ball... not sure why they changed that...
Test probes are gold plated and looks very similar to ones that you can get of eBay for $4.99 however, quality of Hioki probes is completly different, Silicon cable is top. They are not very sharp, probably because this is electricians meter..
If somebody wants to see eBay test leads in comparasion with HIOKI ones let me know.
