Author Topic: HIOKI DT4211/4212 Multimeter Quality  (Read 5510 times)
Offline chawchipTopic starter
« on: July 31, 2014, 02:56:56 am »
Hello,
HIOKI released a couple of new "budget" meters last year, the DT4211 and DT4212. I have seen an and was quite impressed with the build quality and speed of this meter, but it is lacking a milliamp range. The new DT4211 and the DT4212 have a proper milliamp range, but I am wondering if the same level of quality is present in the new DT4211 and DT4212. Specifically do they contain genuine HIOKI and TI chipsets (like the DT4252), and are they manufactured in Japan.
Thanks!
« Last Edit: July 31, 2014, 04:29:46 am by chawchip »
Offline retiredcaps
Re: HIOKI DT4211/4212 Multimeter Quality
« Reply #1 on: July 31, 2014, 05:12:43 am »
My guess from reading the Hioki DT4211/4212 specs of 3 updates/sec, double AA battery, 4000 count with 0.5% DCV accuracy that it is based on some off the shelf IC like a Fortune Semiconductor FS9721.
« Last Edit: July 31, 2014, 05:25:14 am by retiredcaps »
Offline retiredcaps
« Reply #2 on: July 31, 2014, 05:24:41 am »
This auction
http://www.ebay.com/itm/231179359943
shows a picture of the back with the rubber holster off.  Unfortunately, I can't tell from the low resolution picture where the meter was made.
Perhaps someone with better eyes or knows how to use a tool to sharpen the image?
edit: I think I see a T and 6 letters total, so my guess Made in Taiwan.
edit2: Hmm, similarities
http://www.deree.com.tw/proimages/rimages/Digital-Multimeter-DE-240-241-242-243.pdf
« Last Edit: July 31, 2014, 05:37:53 am by retiredcaps »
« Reply #3 on: July 31, 2014, 02:36:17 pm »
I knew it was too good to be true. I am still interested to see inside though.
Offline PedroDaGr8
  • A sociable geek chemist
« Reply #4 on: July 31, 2014, 03:38:06 pm »
As far as manufacturers go, the Der EE multimeters are actually pretty decent. Not quite Brymen level but close and definitely not Chinese quality.
The very existence of flamethrowers proves that some time, somewhere, someone said to themselves, "You know, I want to set those people over there on fire, but I'm just not close enough to get the job done." -George Carlin
Online wraper
  • Country: lv
« Reply #5 on: July 31, 2014, 04:29:17 pm »
Dial positions are different
Edit:
Button functions are also different
Edit 2:
Like DE-243 except button functions are swapped
« Last Edit: July 31, 2014, 04:41:45 pm by wraper »
