Hi everybody,
I'm playing with the fisrt time with the counter of my DG1022. I dont know if it's me but it's really hard to use.
For exemple. I setup a simple square waveform from ch1 and enter it in the counter with a coax. 1 Mhz. 2v peak. No offset.
I check the output signal on scope.... very clean 0 to 2v 50% duty square wave.
To be able to read anything I must set the trigger sense to 95%, level to 0 and coupling is DC. The gate time change only the accuracy.
If I change trigger sens to 85%... result jump all over the place
If I rise trigger lever to only 100mv... nothing
If I lower the frequency to 100khz or 1Khz same result.
If I probe with my dm3068 (On Freq as well), it is showing me the right frequency.
And this is just one exemple. Is it me ? Or it's very hard use. It's pratically useless.
I looked on other thread but nobody is talking about it. It's why I think it is maybe defective ?
Thank you
Yannick
