I am looking for recommendation for the high voltage benchtop power supply.
I owned a pair of voltage and current regulated Kepco BHK series linear HV supplies for close to thirty years. I've got lots and lots of time on them performing "speriments"....
Be VERY careful farting around with supplies that can produce the voltage and current levels you're looking for. They are lethal as hell. Your first opps! can very well be your last.
I use only locking banana plugs and jacks or crimped and soldered eye terminals screwed down. No alligator clamps. All of my jumpers and leads are double insulated silicone and rated 5KV minimum when used with my the 2KV setup. If something pulls loose, it'll get you.
Starting with the power supplies unplugged, I connect what I need to connect, then plug in the supplies with the DC switches off and let the output tubes warm up for a few minutes. Then I'll hit the DC switch....
If something need to be "adjusted", I kill the AC power, unplug the supplies, shut off the switches on the PS and start over. Touch NOTHING when it is powered up.
For real excitement, I have a few fifty pound neon sign transformers that are a real terror. They'll burn right through the 5KV silicone leads. :-)
BE SAFE and double check everything. Seriously!
WoD
