Author Topic: Tracking generator for HP 8567a  (Read 1284 times)
Offline L_EulerTopic starter
« on: January 10, 2019, 07:51:53 pm »
Can anyone recommend a tracking generator for use with a HP 8567A?
There's no point to getting old if you don't have stories.
Offline swingbyte1
Re: Tracking generator for HP 8567a
« Reply #1 on: January 11, 2019, 07:03:10 am »
Hi. The common to suggestion is the 8444a. But they only go to 1.5ghz. the internal look isn't stable enough but an external sg can be used. For higher freq you will have to roll your own. See k5fx site for 8566 the experiments
Sent from my Nexus 5 using Tapatalk
« Reply #2 on: January 12, 2019, 08:34:56 pm »
Thanks, my 87 only goes to 1.5GHz anyway.
Offline PA2HK
« Reply #3 on: January 13, 2019, 11:44:44 am »
For that HP8444A to work in combination with your 8567A, the tracking generator needs to be equipped with option 059 (1500MHz) or alternatively option 058 allowing up to 1300Mhz. A bare HP8444A without option 058 or 059 is designed to work with modules of the venerable HP141T spectrum analyzer system and will not work with your analyzer.
HamRadio PA2HK // Keep Calm and Carry On.
