Author Topic: "High Power" signal generator needed  (Read 1631 times)
Offline wilhe_joTopic starter
  • Country: at
« on: February 08, 2022, 11:18:35 am »
Hi Folks!
I'm in the progress of getting my conducted immunity test setup streamlined (ie. get the conducted and radiated test setup separated).
Up to now, I have a nice Amplifier Research unit which gets moved around... it works, but I'd love to have a fixed setup.
There're several MRF101 amplifier builds around.
I'm confident to build an 150k-80M amplifier (actually, I'll switch between 3 bands for ease of implementation) from the available reference designs.
However, this would only have a power gain of about +20dB...
I guess, having 25W of power would be plenty.
So I'd need 24dBm of drive power (the MRF101 could do 100W@1W drive power).
That's 10dB more than my current generators could do... So I'm out for a new (read: new in my lab, but old and used due to budget constraints) 150k-80Mhz signal gen as well :)
After looking at various data sheets, I only found the Keysight/Agilent 33250a...
That would give me 1W which would be a very nice match for the MRF101.
I'm sure there are more generators in the 24-30dBm range out there (having some pc-interface)... any recommendations???
BTW: Yes, adding a driver-amplifier came up to my mind, but I did not find a "finished" 150k-80MHz 1W preamp design (with available parts).
So I thought trading time vs money and getting a new signal gen would be fine as well :)
73
[edit]
Maybe it makes sense to make a list of these higher-power sig-gens...
GwinstekAFG-308110Vpp @ 50ΩDC-80MHz
Agilent/Keysight33250A10Vpp @ 50Ω1µHz-80MHz
RigolDG5101 (whole DG5000 series)10Vpp @ 50Ωdepends on model
TTiTGF4162/TGF424210Vpp @ 50Ω <=80MHzdepends on model
[/edit]
« Last Edit: February 08, 2022, 06:04:22 pm by wilhe_jo »
Offline bob91343
Re: "High Power" signal generator needed
« Reply #1 on: February 08, 2022, 05:10:15 pm »
Have you considered an amateur radio linear amplifier?  Some of them can deliver kilowatts.  The frequency might not be adequate so you might need two or three different units.
  • Country: at
« Reply #2 on: February 08, 2022, 05:46:43 pm »
Yes, I have... actually I found the MRF101 by looking for some ham-radio stuff.
The 2200m band (just below the 150kHz boundary) is still pretty rarely used.
So there are not too many commercial options. Most do 1.8-30 or 54MHz.
However, you can find several homebrew designs using the relatively new MRF101...
So I think, the amplifier is doable if you can provide enough input power.
Meanwhile I ran through most obvious budget brands (initially, I was searching for used stuff.
73
« Last Edit: February 08, 2022, 05:49:31 pm by wilhe_jo »
Offline bob91343
« Reply #3 on: February 08, 2022, 07:19:55 pm »
For below 100 kHz, consider an audiophile amplifier.
« Reply #4 on: February 08, 2022, 08:47:23 pm »
SDG2082X
SDG6022X ^ both 10V p-p into 50 Ohm uses EasyWaveX SW for remote control
SSG3021X     20 dBm max into 50 Ohm. Has webserver.
Offline 2N3055
  • Country: hr
« Reply #5 on: February 08, 2022, 08:58:49 pm »
Mini circuits ZHL-32A+ or ZHL-32A-S+ as a driver between AWG  and power amp ??
  • Country: at
« Reply #6 on: February 10, 2022, 12:16:30 pm »
SDG2082X
They don't get you the 10Vpp in the whole .15-80MHz range...
Hmm, didn't had these on my radar... sounds an interesting option, thanks! :)
73
Offline AJ3G
« Reply #7 on: February 10, 2022, 03:57:23 pm »
I think some of the Marconi 202X Series has a high power option. If you look you can have one for reasonable money.
Rich
  • Country: at
« Reply #8 on: February 10, 2022, 06:52:30 pm »
Well, I found this in the Marconi 2023/2024 datasheet:
High power
A high power option is available which
provides an RF output up to +25 dBm -
ideal for use as a local oscillator or testing
passive and active components
So that's not bad, but not quite what I'm looking for... In addition, they can't to full power when doing AM:
When AM is
selected, the maximum RF output level decreases
linearly with increasing AM depth to +7 dBm at 99.9%
depth.
I wonder if that's considered in the other data sheets... That's the first one which is that specific on this detail.
73
Offline AJ3G
« Reply #9 on: February 10, 2022, 10:45:52 pm »
Yes, if you have AM Set, it will not allow you to advance the amplitude beyond a certain number. From what the Marconi User Group says this to give you enough headroom when running AM.
Rich
