Author Topic: Hewlett Packard HP461A Wide Band Amplifier  (Read 36397 times)
Online Peter_OTopic starter
Re: Hewlett Packard HP461A Wide Band Amplifier
« Reply #25 on: January 06, 2024, 10:11:23 am »
This probably won't help, but here are some pictures of my 462A, the circuit diagram in a previous post shows the differences, it's a bit older, there are some Ge transistors in the earlier ones, the coils are well sealed to prevent adjustment.
The manual only mentions Q9 having a heatsink fitted, mine is exactly as described, the 461A seems to have a load of extra heatsinks for unknown reasons.
It's always nice to have pictures for comparison.  :-+
My 461A has been tinkered with, no question. Soldering, additional heatsinks, the makeshift one at least, scratched pin labeling at the power transistor, removed seals at the inductors, ...
I don't like the use of a 250mA fuse for both 115V & 230V operation, especially with that tiny transformer.
Yeah. For the moment I have the IR camera at hand when playing.
I'm not sorted in these big US style fuses but in 5x20mm only.  :scared:
« Reply #26 on: January 06, 2024, 10:19:29 am »
snip
Can anyone make out the BJT's in the part list ?
Here's better scan of the service manual.
« Last Edit: January 06, 2024, 10:27:33 am by Peter_O »
The following users thanked this post: edavid, MathWizard
Offline factory
« Reply #27 on: January 06, 2024, 01:14:14 pm »
My 462A seems to have been made just after 1970 (SN 947A-01167), some parts dated 6952 and 0-13 (1970 week 13), it disobeys the manual changes (947-01160 & below) as it still has a red plastic neon indicator & original cover colors, guess they used up what was in stock first and/or had shortages of the later parts. But has a factory fitted IEC, with a big crack across it, from whatever impact cracked the side frame.
Some of the smaller carbon resistors have been disturbed by a previous owner.
Transistor in italics don't quite match anything in the manual, or change sheet, for mine at least, some resistors & capacitors values are different for the 462A, which is optimized for pulse use.
Q3 is 1850-0106 (Ge)
Q4 is 4-073 (aka 1854-0073, 2N3478)
Q5 to Q7 are SS98 (aka 1854-0305)
Q8 is 2N3663 (aka 1854-0219)
Q9 is 54-19 (aka 1854-0019)
As usual some unknown spec. selected parts with custom numbering for HP, can't rely on the NSN lists for the Ge one, as it mentions several Si parts on the same page.
Earlier ones used 1854-0031 (aka 2N2218A) for Q4 to Q8, they state to use the newer part list it any fail & replace as a set of 5.
The broken tuning slugs are a problem, they are usually made from slightly different materials depending on the the frequency.
Fuses are quite well stocked here, some modern ones have nuisance blow proprieties that the older ones didn't (in a 711A), I bought some older Littelfuse/Bussmann ones from a seller in Greece a few years ago, old enough to be packed in metal tins (Qty. 5), price in quantity was better than RS at the time.
« Last Edit: January 15, 2024, 07:44:29 pm by factory »
The following users thanked this post: MathWizard, Hamelec
Offline MathWizard
« Reply #28 on: January 10, 2024, 06:24:30 pm »
Ok I missed your replies, thanks. Yeah I wondered if Q3 was some old Germanium thing with a low VBE.
Offline factory
« Reply #29 on: January 10, 2024, 08:06:57 pm »
The custom parts had their required spec detailed in HP lists, one or more vendors would provide devices that met the specs, employees had access to these lists on Microfiche, which seem to have mostly been lost to time, but someone sent CuriousMarc some, none of these are available to view/download anywhere that I know of.
Transistor 1854-0019 is shown at 9.33 in the video, it doesn't have a Jedec part number, but does have some specs that should help find an regular part.
https://youtu.be/MshAFrOgW1A?feature=shared&t=573
« Last Edit: January 10, 2024, 10:19:34 pm by factory »
Offline factory
« Reply #30 on: January 10, 2024, 10:22:15 pm »
Note: the various circuit diagrams cover two different versions, the older one covers the unit with 3 Ge transistors (Q3 & both in the PSU), the later ones are all Si (there are two of these with differing voltage readings for Q9).
Seems the OPs newer unit doesn't follow any of the available manuals for the PSU section, it has two differing values for R5/R6 in the PSU, but the manuals show them both as the same value, which may or may not be wrong.  :-// As they changed from Ge to Si transistors, Zener is slightly different voltage too.
« Last Edit: January 10, 2024, 10:24:23 pm by factory »
Offline Tony_G
  • Checkout my old test gear channel (link in sig)
    • TGSoapbox
« Reply #31 on: January 11, 2024, 01:48:17 am »
I don't think I ever took a photo of my 461A but I grabbed this from a video I did on the repair of it:
Assuming that it wasn't touched then the original only had a single heatsink as well.
The manual only shows 1 heatsink as well:
I never did get around to fixing the missing slug in the first inductor from memory...
TonyG
Offline factory
« Reply #32 on: January 15, 2024, 07:40:21 pm »
Yours seems a little newer than mine, but both have Ge transistors for the PSU, interesting that they fitted one capacitor instead of the five that most have.
It seems some of the HP component lists on Fiche, from the 1980s are now available to download, thanks to CuriousMarc for adding them here; https://archive.org/details/@curiousmarc
Offline Tony_G
    • TGSoapbox
« Reply #33 on: January 16, 2024, 04:21:12 am »
I can't remember if I ever saw a schematic for the new power supply but I did end up getting the unit just in cal at +/- 0.5 dB for 20 & 40.
Look forward to hearing that you have yours working well too.
TonyG
« Reply #34 on: January 17, 2024, 08:05:27 am »
I will continue with this project.  :-+
At the moment time is short. My mum is relocating from hospital to a nursing home, and there is a lot to deal with.  :(
« Reply #35 on: April 01, 2024, 02:01:28 pm »
I just returned to the bench.
From a lab PSU the amp draws 100mA per rail: +15V and - 15V.
The ripple of the orginal PSU is 8mV instead of <1mV acc. to spec.
Now I'm not sure:
a) is the amp drawing to much current and cause the psu ripple out of spec?
b) are the filter caps out of spec?
b: I checked all of the filter caps C1-C5:
spec µF   real µF   ESR Ohm
C1-C5   65810.8
780.8
701.0
790.7
801.1
and also C6 and C7:
C6      20243.2 (problem?)
C720221.9
ALL resistors are OK.
With the output disconnected, the PSU delivers 30V OK, the tranformer stays cold, but R2 and R3 get very hot at about 110°C in about a minute.
Voltage over R2 and R3 together are 60V (!) which would be 0.8W per resistor.
Unfortunately I shorted the -15V rail to ground with the DVM probe while measuring the voltage over R2.  :palm:
So for the moment the damage has gotten worse and do I qualify as a rooky obviously (see first post).
That fault aside, the central question reg. the psu seems to be: Is 2x44V RMS at the transformer outputs OK?
I had checked the 110/230 switching and that was OK, delivering 230V to the outer contacts of the primary side.
Maybe someone of you owning a 461 or 462 can check the transformer output voltages?
If the 2x44V of my one are wrong, I would give futher tries to get the puppy running a miss for the moment. Otherwise I would need to fix the damage of the short first.  :scared:
« Last Edit: April 01, 2024, 02:03:46 pm by Peter_O »
Offline coppercone2
« Reply #36 on: April 01, 2024, 09:15:24 pm »
I am angry at the thought of opening that thing up again after having to remake the springy thing for the attenuator, but I think you should hold off working on it until you buy some multimeter probe sleeves or insulated multimeter probe tip attachment. I destroyed (and repaired) a 30A 30V psu that way. Fluke has some stuff but you can probobly do better. Before you make the mistake again and destroy the transformer or something like that.
I keep a miniature plastic organizer box of all the DMM slip on tips and stuff on my bench because slipping that little plastic on the probe (conveniently) can easily save you 30 hours work or a throw away.... also recommend a pressurized can of spray alcohol and cotton wipes in the DMM probe attachment kit (cut into little squares) so you keep the probes clean because alot of the time the problem that causes slipping is excess pressure to compensate for dirty probes. Fiber scratch pen and q-tips can be helpful to for cleaning probe points on the old meter before you work so you can just glance it and get a good measurement. and I have been meaning to make some partially cut probe sleeves so I can expose one side of the probe if I need to do the measurement along the shaft
there is gold probes too but that is expensive i cant suggest buying that for most people lol but the probe tip attachments and sleeves are a requirement for safe work. But you need to set it up so its conveniant and you chose the optimal probe configuration for every measurement you do without it being a hassle
gooseneck lamp or head lamp too, way more useful then blowing budget on lab lights
I always end up breaking stuff if I do electronics while there is something stressful going on, and I also think there is something infuriating about the design of that amp that effects my judgement lol
Maybe I will open it later but hopefully someone else that has less history with the unit can do it.
« Last Edit: April 01, 2024, 09:26:53 pm by coppercone2 »
The following users thanked this post: Peter_O
« Reply #37 on: April 02, 2024, 08:41:42 am »
Yes.  :-+
The problem is standing in front of the drawer with probes and accessories like DMM probe sleves.   :-DD  :-[
Maybe it's nesserary to get a kick in the ass from time to time.
First I will check the transformer again.
Offline David Hess
  • DavidH
« Reply #38 on: April 02, 2024, 04:42:24 pm »
I have started keeping my multimeters and other portable gear in hard cases, where I can also keep the probes and accessories, as shown below.  For my oscilloscopes some of my oscilloscope carts have drawers, but for other accessories, I have settled on divided plastic boxes.
I am very happy with the test lead kit I bought for my old Beckman Circuitmate multimeter from Probemaster for about $50 total.  They were able to supply it with non-safety right angle plugs to fit my multimeter.
https://probemaster.com/8000-series-kits/
« Reply #39 on: April 02, 2024, 05:21:45 pm »
Yup. I have drawers of test leads etc. The trick is to use them.   :-DD
Back to the topic:
I fixed the PSU so far.
The transformer is still alive, showing the same resistances as before.  :phew:
In the end only the zehner diode whas shot.
With one 0.5W chinesium one from my stock the PSU is running again; but the zehner is getting hot very quickly because it's only 0.5W instead of 1W.
Next step is to purchase proper zehners: Acc. to lists it's a HP 1902-0202 or ZS11213-191; 15V, 1W.
On the way I found a fault that came with the device:
Output-PIN 6 and 7 (one secondary coil) of the transformer had been connected the wrong way. :scared:
That's interesting because the wire connection at the transformator looked original 70's style and the wires looked original. Is it possible, that it had been wired wrongly at the factory?
Here the faulty wiring:
Anyhow. Now it matches basic logic, the schematics and the manual too, which states "red" at PIN 6.
When the proper zehner is in, we'll see, if the transformer stays cold.
« Last Edit: April 02, 2024, 09:19:28 pm by Peter_O »
Offline coppercone2
« Reply #40 on: April 03, 2024, 04:48:33 am »
picture 2 almost looks identical to my probe boxes lol
you are missing BNC to screw terminal for $1.27. so it fits a twisted pair more perfectly then a binding post
actually never mind, its not similar, because I made a solid oak box with cut outs for most of the coaxial connectors. Banana stuff is in a box like that still. I poured silicone rubber compound (2 part) into drill holes to make safe platforms to hold connectors. I thought they are too valuable to stay in the plastic box. I think I need to make a third box now  :). But I keep the unterminated connectors in a box for cable making, not adaptors
« Last Edit: April 03, 2024, 07:33:36 am by coppercone2 »
Offline factory
« Reply #41 on: April 03, 2024, 10:25:23 am »
Back to the topic:
I've still got mine here (462A) if you need any readings, it seems obvious now but must have been the last thing you suspected, mine has the centre tap going to the red wire and the two outer ones (the same colors) going to the rectifiers.
« Reply #42 on: April 05, 2024, 09:09:57 am »
Thx for providing the pic, David!
Interestingly your's are different pcbs:
The PSU board showing the vintage HP-logo and different connections,  and the amp board with rounded tracks.
The wire colors are the same.
The zehner diode is announce to arrive today.
« Last Edit: April 05, 2024, 09:12:12 am by Peter_O »
Offline factory
« Reply #43 on: April 05, 2024, 09:34:23 am »
The PSU should be the same design, the older one in my 462A is the "OR" or original version, the newer board in your 461A is revision A. Interesting the older PSU seems to have all the traces on the back, the newer one a mix with them on both sides.
The amp boards have different part numbers, one being 00461-66502 (Rev C) & the other 00462-66502 (Rev A) for obvious reasons. The later boards all got redesigned at some point, to use straight traces & sharp corners, most products from the 1960s that were made for many years, had these changes.
There are more the pictures of my 462A attached to reply #22, if you want to see the differences.
« Last Edit: April 05, 2024, 09:37:20 am by factory »
