Author Topic: Hewlett Packard 522B counter  (Read 2755 times)
Offline MaxFristerTopic starter
« on: July 15, 2022, 06:57:51 am »
I recently picked up an new project, a Hewlett Packard 522B counter.
So far I've given it a good cleaning and tested the 49 vacuum tubes.  Waiting on new caps and NOS tubes.
« Last Edit: July 15, 2022, 07:00:52 am by MaxFrister »
The following users thanked this post: edavid, bd139, factory, AVGresponding, Detlev
Re: Hewlett Packard 522B counter
« Reply #1 on: July 15, 2022, 07:11:31 am »
Very cool. Interested to see how your refurb goes  :-+
« Reply #2 on: July 15, 2022, 01:49:03 pm »
Up to 200V pk-pk trigger!   :o
Offline edpalmer42
« Reply #3 on: July 15, 2022, 04:13:49 pm »
This is one of the very few cases where HP rebadged another company's product.  This is an EPUT (Event per Unit Time) meter from Beckman/Berkeley.  I had one long ago.  I think mine had 6 digits.
Ed
« Last Edit: July 16, 2022, 04:17:28 am by edpalmer42 »
The following users thanked this post: bd139, AVGresponding
« Reply #4 on: July 15, 2022, 05:02:29 pm »
Basic specs:
Measures: Frequency, period, time interval measurement, ratio, total events
Introduced: 1953
Original price, $900 — approx. $10k in today’s dollars
Frequency measurement: 10cps to 150kcps (cycles per second, hertz has not been invented yet).
Time interval: 10uS to 27.8 hours
Includes self check
49 Vacuum tubes
Based upon AC-4A/B counter modules
Power required 260Watts
Weight 45lbs in the “portable” case
Ovenized crystal oscillator.
Stability: 10ppm per week, can be standardized to WWV (if only it still existed).
Accuracy: +/-1 count + stability
Input required +/-0.2V to 100V, positive or negative triggering.
Input: direct coupled, 1M ohm impedance shunted by 50uuF (the picofarad had not been invented).
Can provide an overflow count to allow more than 5 digits of counting
Can provide 90V to power a photo tube
With an optional circuit, can provide output for a plotter or printer
This particular unit was manufactured circa 1956 and the last cal was in 1971.
Manual:
http://ftb.ko4bb.com/manuals/24.113.155.190/HP_522B_Frequency_Counter_Service_Manual.pdf
Manual for AC-4A/B counter modules:
http://www.hparchive.com/Manuals/HP-AC-4A-4B-Manual.pdf
HP Journal Article: Sept/Oct 1953:
http://www.hparchive.com/Manuals/HP-523B-Manual.pdf
1954 catalog entry:
http://www.hparchive.com/Catalogs/HP-Catalog-1956-10-Revised.pdf
Related machine: 523B:
Related machine, HP 524B (Circa 1952):
HP Journal Article HP 524B, March/April 1954:
Offline Wrenches of Death
« Reply #5 on: July 16, 2022, 03:02:58 am »
Pretty sure that WWV is still kicking. The last time I checked, they were up on 2.5, 5, 10, 15, and 20 megacycles. I haven't heard them on 25 megacycles in a very, VERY long time.
WoD
« Reply #6 on: July 16, 2022, 01:31:20 pm »
I’m glad to hear that WWV is still kicking.  I recalled reading that they were planning to shut it off.
Here is a pic of the 522B internals before cleaning and disassembly
« Last Edit: July 16, 2022, 01:56:21 pm by MaxFrister »
« Reply #7 on: July 16, 2022, 01:48:56 pm »
Of the 4 dozen tubes around 5 tested bad or weak.
The following users thanked this post: Dr. Frank, bd139
« Reply #8 on: July 16, 2022, 01:50:25 pm »
Most of the replacements have arrived.  Of course the one I needed first for the PS arrived from that awful auction site not as NOS but old and bad.
« Reply #9 on: July 16, 2022, 01:51:45 pm »
I’ve started the cap replacement.  Here I’m using a period appropriate Cornell-Dubilier BF-70 analyzer to reform a NOS can cap.
Offline TimFox
« Reply #10 on: July 16, 2022, 04:22:37 pm »
Amusing detail about the CDE test unit:  the "common" post is red, while the "R" and "C" are black.
« Reply #11 on: July 16, 2022, 04:42:21 pm »
And indeed common is positive.  That seems to have been "common" for magic eye bridges.  My Heathkit C-3 Condenser checker is the same except that the common terminal is also black.   I have to remember that little quirk every time I get it out.
Offline edpalmer42
« Reply #13 on: July 16, 2022, 08:43:24 pm »
Someone has sent me a clean copy of the schematics.  They should be available in a couple of days at http://www.ko4bb.com/getsimple/index.php?id=manuals.
Offline Cubdriver
  • Nixie addict
    • Photos of electronic gear
« Reply #14 on: July 17, 2022, 07:20:57 am »
Cool old beast, and definitely a room heater!  Nice score!   :-+ :-+
-Pat
« Reply #15 on: July 18, 2022, 03:57:34 am »
Here is a picture of the bottom of the instrument. The object on the right is a delay line.
« Last Edit: July 18, 2022, 04:10:18 am by MaxFrister »
The following users thanked this post: Cubdriver, AVGresponding
« Reply #16 on: July 18, 2022, 04:02:49 am »
It was a bit of a challenge to find room for the replacement caps:
« Reply #17 on: July 18, 2022, 04:04:38 am »
Here's a pic of the high-tech selenium rectifier:
Offline Cubdriver
  • Nixie addict
« Reply #18 on: July 18, 2022, 05:00:55 am »
What's that towards the rear on the right side of the chassis underside picture - a stack of doorknob caps, or a tapped coil?  Despite having one for several years now I have never opened and looked at the underside.
Great pictures, too!   :-+
-Pat
« Reply #19 on: July 18, 2022, 05:34:02 am »
That's the delay line, DL101.  Ten sections of 60mH and 68pF each.
It's part of the reset circuit.  According to the manual:
"The pulse to the Signal Gate is delayed twenty microseconds by Delay Line DL101 to give the counter circuits time to reset and stabilize before they receive the new signals."
« Last Edit: July 18, 2022, 05:39:06 am by MaxFrister »
« Reply #20 on: July 19, 2022, 04:00:40 am »
It can count!
After completing the recap I installed just 2 of vacuum tubes and brought up the machine on a variac and dim-bulb.  After verifying that the -105V rail was present, I added 2 more tubes and tried the +200V rail.  Also present.
At that point I removed the dim bulb and reassembled the machine.  Again I bought it up on the variac and confirmed that current draw was okay.    Somewhat to my surprise it almost worked.  The count was off but consistent.
After 50+ years since the last calibration, the machine was due for adjustment.  After I adjusted  the power supply and the “phantastron” dividers it passed self-test.  After tweaking the OCXO, it was accurate.
Summary:
Replaced AC cord.
Replaced 8 vacuum tubes
Replaced the selenium rectifier
Replaced paper and electrolytic caps (I left the original precision paper/oil caps as they tested okay).
Adjusted the machine.
Beware: It turns out that 2 of the caps are marked in reverse polarity in the original schematic and the machine was wired that way.  I’m not sure how they got away with that but maybe old caps are not as touchy about reversed polarity as new ones.  Anyway, C130 and C131 should have the polarity reversed on the negative rails.
« Last Edit: July 19, 2022, 04:03:37 am by MaxFrister »
The following users thanked this post: johnboxall, Cubdriver, bd139, factory, AVGresponding, Detlev
Offline Cubdriver
  • Nixie addict
« Reply #21 on: July 19, 2022, 04:41:31 am »
Looks great!  Nicely done!
-Pat
