Author Topic: Siglent SDM Calibration Files - Help wanted to test !  (Read 772 times)
Offline TheDefpomTopic starter
  • YouTuber Nerd - I Fix Stuff
    • The Defpom's Channel
« on: March 02, 2023, 08:36:17 pm »
Hi All,
Some of you may know that I built the SDM3065X, SDM3055, SDM3045X calibration file generator site: https://www.thedefpom.com/siglent_sdm_calibration.php
I haven't had a lot of feedback about it so I don't actually know if all of the files are working correctly.
I am hoping that people out there with the SDM3065X, SDM3055 or SDM3045X that have tried using the site will post the results of trying to use the files here, both good and bad, so I can try to track any problems with the files it is generating.
I want to compile a table showing all of the confirmed working files, and also the ones that are not working, if you have a problem with one not working I may ask you to do further testing when I attempt to modify the file formats.
Unfortunately there are no real examples for all of the files from Siglent and so some are based on guesswork and may not be working, this is why I want to nail this down and be sure that there is a known status for each file and calibration type.
One interesting point is that all the example cal files are 2,400,000 (or 240,000) count based, but the SDM3045X is a 66,000 count meter, so I am really unsure if the files work for it at all.
ModelModeResult
SDM3065XDCVWorks
SDM3065XDCV Auto ZeroWorks
SDM3065XACV-
SDM3065XACV 3Hz Filter-
SDM3065XDCIWorks
SDM3065XDCI Auto ZeroWorks
SDM3065XACI-
SDM3065XACI 3Hz Filter-
SDM3065X2 Wire R-
SDM3065X2 Wire R Auto Zero-
SDM3065X4 Wire R-
SDM3065X4 Wire R Auto Zero-
SDM3065XCapacitance-
ModelModeResult
SDM3055DCV-
SDM3055ACV-
SDM3055DCI-
SDM3055ACI-
SDM30552 Wire R-
SDM30554 Wire R-
SDM3055Capacitance-
ModelModeResult
SDM3045XDCVWorks
SDM3045XACV-
SDM3045XDCI-
SDM3045XACI-
SDM3045X2 Wire RErrror in recalibrated mode or range
SDM3045X4 Wire RErrror in recalibrated mode or range
SDM3045XCapacitance-
« Last Edit: March 02, 2023, 09:14:44 pm by TheDefpom »
Cheers Scott
The following users thanked this post: tv84
Re: Siglent SDM Calibration Files - Help wanted to test !
« Reply #1 on: March 15, 2023, 11:20:03 pm »
Anybody?
Cheers Scott
