Hi
I got an N9912A which is a very early model (I think 2008). It could not boot because the front panel board was dead which I replaced with a board that I had bought (aimlessly) for parts long time ago for $40 even though I never thought I would need it one day
So anyways, the unit boots now with no errors and measures (both SA and VNA) and works fine except that RF board serial and part number/identity and SB serial and part numebr (whatever that means) show up as "?" in the system info page.
I noticed that two components (
U7 and U6) on the main board have been removed - see attached photo.
I am surprised that the unit does not complain...but I guess they must have something to do with the problem I just described
I have not tested the LAN and SD card but USB port works. So maybe those are not working either...
I cannot find any photo of this main board anywhere to figure out what those components must be. I am sure they are either some kind of voltage regulator or maybe a logic gate.
I was wondering if anyone has a similar main board or pictures of it that can help me to identify the two missing parts
