Author Topic: Help: Rigol DS1054Z waveform corruption in stop mode  (Read 18425 times)
Offline keef
Re: Help: Rigol DS1054Z waveform corruption in stop mode
« Reply #75 on: June 21, 2019, 04:16:08 pm »
Great news guys! Rigol sent me an email with the new firmware!
Thanks for the head up! Had been having the same issue, now all seems good! :D
Offline Adrian_Arg.
  • Country: ar
« Reply #76 on: June 21, 2019, 05:18:50 pm »
great, and because you do not share it so that the one with the same problem solves it. >:(
Offline nwfallTopic starter
  • Country: ru
« Reply #77 on: June 21, 2019, 05:53:01 pm »
Oh come on! Will you take a firmware binary from an unknown person on the internet and will flash to your beloved oscilloscope?
I might have a virus on my PC that turns touched devices into a grand scope-o-botnet without my knowledge!
I highly recomend you to download firmwares only from official website.
But if you still want it then here it is :)
Offline WhichEnt2
  • Country: ru
« Reply #78 on: June 21, 2019, 06:47:06 pm »
They already uploaded it: https://rigol.com/Support/SoftDownload/3 version: 00.04.04.04.03 date: 2019-06-21
Short pieces, high value, small period, huge amount, long delay.
The following users thanked this post: RoGeorge, Jacon, nwfall
Online bdunham7
« Reply #79 on: June 21, 2019, 07:00:55 pm »
I find Russian shareware and hackware to be at least as trustworthy as anything from Microsoft--and more so than Apple or Sony!  So I took the risk and installed from your .zip. Is my DS 1054Z now mining Bitcoin for you?  The fan is pretty loud now.... :)
Offline form
« Reply #80 on: June 21, 2019, 07:25:05 pm »
Nope.
I just updated an old DS1074Z from a year-2015 firmware to todays 00.04.04.04.03 and get the same glitch when scrolling in a captured 1 kHz test-signal.
(Did it twice)
Offline RoGeorge
« Reply #81 on: June 21, 2019, 07:50:42 pm »
Interesting.  Was the upgrade to 00.04.04.04.03 successful?
Current installed firmware details can be checked like this:  Under the Trigger area on the front panel, press Menu > Menu > Force > Menu and then press Utility > System > System Info
https://rigol.desk.com/customer/en/portal/articles/2286510-how-to-check-the-full-firmware-and-hardware-revision-on-a-ds1000z-oscilloscope
Offline form
« Reply #82 on: June 21, 2019, 07:54:34 pm »
Yes.
I did not had the issue with the very old 2015 firmware, was waiting to update until the issue was solved, risked it now and got hit :(
Online bdunham7
« Reply #83 on: June 21, 2019, 10:51:57 pm »
After this update, what should my revision level be under Utility/System/SystemInfo?  I have 00.04.04.SP4 and I am unable to access the full firmware information using the method stated above by RoGeorge.
« Last Edit: June 21, 2019, 10:54:30 pm by bdunham7 »
Online MarkF
« Reply #84 on: June 22, 2019, 02:31:17 am »
You need to press the "Menu > Menu > Force > Menu" button sequence pretty fast.
These are the buttons on the right side of the scope under the trigger adjustments.
Then go display the expanded SystemInfo.
Online bdunham7
« Reply #85 on: June 22, 2019, 02:36:36 am »
Thanks!  I was doing it methodically and slowly.  Lightning fingers fixed it.
  • Country: ru
« Reply #86 on: June 22, 2019, 07:13:09 am »
Nope.
(Did it twice)
Was your old 74z working without issues before flashing fresh firmware?
Oh, yes, I see now. Well, that looks suspicious!  :(
« Last Edit: June 22, 2019, 07:15:35 am by nwfall »
Offline form
« Reply #87 on: June 22, 2019, 07:14:18 am »
Yes.
  • Country: ru
« Reply #88 on: June 22, 2019, 07:18:31 am »
Yes.
And what about your recent 1054z? In my mind you had one at work?
Offline form
« Reply #89 on: June 22, 2019, 07:20:09 am »
I returned that a few days after purchase because of the bug and bought a used 1074z without that bug.
Offline JohnPen
« Reply #90 on: June 22, 2019, 09:13:12 am »
Just for info I have updated my, purchased in 2015, DS1054Z to the latest F/W using the formal link with no problems.  In my case I couldn't create the problem previously and this upgrade has not introduced it on my scope.  That said varying tolerances on h/w limits combined with f/w can be rather tricky to deal with sometimes and may well be the problem in 'form's case.  I should point out that I have always upgraded to the latest f/w shortly after each new version has occurred.  It should of course not make any difference when one does a f/w upgrade as all versions should work ok.  I hope no-one else has any problems as otherwise there will need to be another upgrade soon which is not a good advert for Rigol.
Online MarkF
« Reply #91 on: June 22, 2019, 12:15:15 pm »
Nope.
(Did it twice)
My DS1074Z is from about the same time.  I seem to remember that with the very old bootloader, you could install old firmware versions.
I have not tried it on mine.  But, I have some very very old firmware versions saved if you would like to try to go back.
The oldest I have is DS1000ZUpdate_00.02.01.01.00.  Do you know what your working version was?
My scope rarely shows the problem with 00.04.04.04.02.
Offline form
« Reply #92 on: June 22, 2019, 01:23:49 pm »
This sounds good, i will give it a try. Can you please upload all the versions you have? :D
Unfortunately i dont know which version i had before.
Are you going to test it with 00.04.04.04.03?
Online MarkF
« Reply #93 on: June 22, 2019, 03:13:27 pm »
Here is the oldest firmware that has the jitter fix:   Version DS1000ZUpdate_00.04.02.04.07
I have five more but I am not going to upload them til you see if you can revert to an older version.
Yes.  I intend to update to the latest after it shows up on the Rigol North American site.
Which is where all my versions came from.
Online MarkF
« Reply #94 on: June 22, 2019, 03:16:14 pm »
Here is what I have to pick from:
Offline form
« Reply #95 on: June 22, 2019, 03:23:37 pm »
Thank you. I tried that, but the scope won't let me downgrade.
Offline Miti
« Reply #96 on: June 22, 2019, 11:53:11 pm »
Not only that it didn't fix anything but it made it worse. Before I had to play for quite awhile with the buttons, now it shows up pretty fast.
Yes, I appreciate Rigol fixing issues... if they are indeed  fixed. I need to downgrade.  |O
Edit: Anybody knows how to downgrade this sucker? Pissed off!
« Last Edit: June 23, 2019, 12:06:16 am by Miti »
Fear does not stop death, it stops life.
Offline jbtronics
« Reply #97 on: June 23, 2019, 01:20:47 pm »
Interesting that they bring out a new firmware.
I have contacted Rigol (Europe) in beginning of May, and they said that this is most likley an hardware defect and that i should sent the oscilloscope in for repair.
I have sent it in, and now it does not show this corruption issue any more. The unit I have got back is the same as i sent in (same serial number). The only change that i could notice from the outside, that another (but older) firmware was installed (version v00.04.04.03.05 from 2018). Im not sure, but i think that i have installed the old firmware version before (and upgraded later) and the issue were occuring there too, so i think that during the repair something was changed on the hardware.
Offline tv84
  • Country: pt
« Reply #98 on: June 23, 2019, 01:27:00 pm »
There are two ways to downgrade:
1. Patching the .GEL footer of a previous FW:
https://www.eevblog.com/forum/testgear/rigol-dsxxxx-gel-firmware-file-format/msg1479419/#msg1479419
You would have to do the homework.
2. Using Rigol's USB vendor disk
How to get one is also in the forum somewhere.
The safest way is to wait for Rigol to undo the "upgrade".
Offline Miti
« Reply #99 on: June 23, 2019, 04:59:15 pm »
I remember seeing some instructions somewhere but I can't find it to save my life. Can you point to the thread?
Thanks!
