Hello everyone! I just bought a new Rigol DS1054Z!
But it seems like there is a problem with it
I'm not quite sure, maybe this is normal behavior... Please tell me if i'm doing something wrong.
I'm using single trigger mode to capture the signal waveform (it is shown on first two frames of attached image). I'm dialing horizontal scale and position knobs to inspect different places of the waveform.
Then, at random moment, a glitch suddenly appears on the waveform at random place - the waveform becomes corrupted. As far as I understand the waveform shouldn't change in stop mode, because it is stored in memory, right?
Ok, I'm dialing knobs again to take a closer look at the glitch and getting even more glitches. Not right away, but again, at random moments. Theese glitches appears during manipulations with the horizontal knobs.
I'm new to digital scopes. Is the scope has a malfunction? Or it is a normal behavior?
Software version: 00.04.04.04.01
Board version: 0.1.4
Boot version: 0.0.1.5
Firmware version: 0.2.3.11
