@tautech
Hello , I hope everyone is doing great.
I am having problems with my SDS1102CML+ DSO, Its Stuck at BOOT logo, I tried doing factory recovey but it isnt working, Below is my Serial Log. I request @tautech and other to provide the solution for the same.
U-Boot 2013.01.01-svn29730 (Mar 27 2017 - 19:02:34)
I2C: ready
DRAM: 128 MiB
NAND: 256 MiB
MMC: OMAP SD/MMC: 0, OMAP SD/MMC: 1
Using default environment
set_default_env::7864
musb-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, bulk combine, bulk split, HB-ISO Rx, HB-ISO Tx, SoftConn)
musb-hdrc: MHDRC RTL version 2.0
musb-hdrc: setup fifo_mode 4
musb-hdrc: 28/31 max ep, 16384/16384 memory
USB Peripheral mode controller at 47401000 using PIO, IRQ 0
USB Host mode controller at 47401800 using PIO, IRQ 0
Net: <ethaddr> not set. Validating first E-fuse MAC
cpsw
Hit any key to stop autoboot
(Re)start USB...
USB0: lowlevel init failed
USB error: all controllers failed lowlevel init
Download Linux from USB to Nandflash...
** Bad device usb 0 **
Booting from nand ...
NAND read: device 0 offset 0x3080000, size 0x300000
3145728 bytes read: OK
## Booting kernel from Legacy Image at 80200000 ...
Image Name: Linux-3.2.0+
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 2157768 Bytes = 2.1 MiB
Load Address: 80008000
Entry Point: 80008000
Verifying Checksum ... OK
Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
init started: BusyBox v1.13.2 (2012-04-08 17:28:57 CDT)
starting pid 519, tty '': '/etc/init.d/rcS'
rS in
/etc/init.d/rcS: line 15: setterm: not found
starting pid 536, tty '/dev/ttyO0': '-/bin/sh'
Processing /etc/profile... Done
/ # ./SDS1000_arm.app: relocation error: /usr/lib/libglog.so.0: symbol _ZNSt15basic_streambufIcSt11char_traitsIcEE6setbufEPci, version GLIBCXX_3.4 not defined in file libstdc++.so.6 with link time reference
With Pendrive 4GB
U-Boot SPL 2013.01.01-svn29730 (Mar 27 2017 - 19:02:34)
config ddr_pll_config()++
config ddr_pll_config()--
nand_init+++++
nand_init-----
Lcd_Init()++
SetUpLCD()++
SetUpLCD()--
len=768052, height=480, width=800
Logo from nandflash: base=0x81000000; end=0x810bb81f; end-base=0xbb81f; rwsize=0xbb820; r=0x0
Lcd_Init()--
I2C: ready
DRAM: 128 MiB
NAND: 256 MiB
cpsw
(Re)start USB...
USB0: scanning bus 0 for devices... 1 USB Device(s) found
scanning usb for storage devices... 0 Storage Device(s) found
OK
Starting kernel ...
rS in
