Author Topic: Solve the Mystery! Help Me Removing Back Cover Rigol DS4024 Scope  (Read 5445 times)
Offline martys
Re: Solve the Mystery! Help Me Removing Back Cover Rigol DS4024 Scope
« Reply #25 on: July 22, 2017, 12:16:53 pm »
Sorry, was soon going to edit my post and add it in. This one has 12 detents/rev. and fits perfectly.
PEC11R-4215F-S0012
Bourns Encoders
The 12 at the end of the part# specifies the number of detents.
« Last Edit: July 22, 2017, 12:43:29 pm by martys »
Offline texaspyro
« Reply #26 on: July 22, 2017, 02:00:44 pm »
My preferred method of removing labels and stickers that I want to preserve is to use a product called UnDu.  It contains heptane and temporarily causes adhesives to forget how to be sticky.   I use a thin wire like a cheese knife to slide under the label.  My preferred wire is 0.005" tungsten wire.  Slide the wire along the label and with a sawing motion, applying UnDu as you go.  Also a single edge razor blade works well if the label  is not in some recess that prevents use of a razor or sewing needle.
UnDu can be found  at hobby stores... look in the scrapbooking section.   It costs more than it should...  I found a heptane based rubber cement thinner that for a 1 quart can cost less than a 2 ounce bottle of UnDu.
