tequipment.net
Rigol DS2072 $839usd.
Rigol DS2102 $1143usd.
Rigol DS2202 $1626usd.***** 2GSa/s.
http://www.tequipment.net/RigolDS2202.htmlInstek GDS-3152 150 MHz 2 Channel $1652usd. 2.5GSa/s.
Instek GDS-3154 150 MHz 4 Channel $2012usd.***** 5GSa/s.
http://www.gwinstek.com/en/product/productdetail.aspx?pid=3&mid=7&id=1290http://www.testequipmentdepot.com/instek/oscilloscopes/gds-3154.htmRigol DS4022 $2600usd.? 4GSa/s.
http://www.tequipment.net/RigolDS4022.html
I write because i need help, i´m a begginer, and i know the value of having the right tool,
but can´t decide what to buy, with the budget i have....
I feel bad to post this on the forum.
here is the dilema:
2GSa/s vs. 5GSa/s,
but,
2GSa/s with Big memory vs. 5GSa/s with small memory.
2GSa/s with better Ultravision vs. 5GSa/s with inferior VPO*.
I really love the Instek gds-3154 75ohm inputs & 5GSa/s.
want to measure SQRs from Agilent 33500B at 25MHz,
and decode some s/pdif signals running at 192Khz, "6MHz" from my soundcard.
but can´t decide, whats better for me.
UltraVision & memory or 5GSa/s & 75ohms.
Memory could replace a Logic Analizer,
but...
Impendace is very important for me, i have a Leader Analog SQR signal generator,
connected to a Drawmer D-Clock, but didn´t worked,
the idea was to see if i could measure it, vs. the freq. counter of the scope.
the Drawmer had a Hi-Z or 75ohms switch, and magically it worked at Hi-Z.
i don´t understand much about impedances, but i know 75ohms is very important for me.
Anyway...
Agilent dsox3k is out of the budget.
I had Instek gds1102A-U with big memory and i was very happy with it, far better than any other, in that $ range.
but the RT 1GSa/s was not enough, no VPO, & yes, slow cpu when multiple features are running, probes were not exactly x10,
more like x5.5, useless for "high voltage" measurents, anyway...
Rigol 2k it´s in a new league, it´s more like a 3K with a 2K price.
solution could be the DS4K.?
but is $600usd. more with 2ch & 1GSa/s less... ?
& still has no 75ohm input.
and does not have the 0.5mV/div of the 2K..?,
i want to measure some Phono signals, later, Phono signals are very small.
also i want to align old FM radios, with a Scope, instead of the ST1000A.
Help!
I´m about to make a mistake?
Thanks.
*Assuming VPO in the 2OOOA is = to the 3OOO, but seems VPO in the 3K is more advanced...
Found some reviews about the DS4k.
