I hope you allow me to add my questions to this thread as I'm essentially in the ever same "don't know what to buy" situation that drives the veterans nuts in EVERY forum...
I lost my previous scope due to a flooding in my basement where the item was stored in a shelf that time. The device was soaked in muddy waters and "dead" afterwards. It was a trusty "all analog" device. Not the top notch finest premium selection, but definitely well beyond entry level. The good thing is, that the insurance agreed to pay for a "suitable replacement". Whereas "suitable" might be arguable, but we agreed that this does not mean the cheapest possible solution to get up to the former nominal specs of the broken one but rather "
a current available device from a reputable but not premium brand at a comparable model level".
That brings me in the lucky situation to shop for a scope in the 1k to 1.5k price range that will be usable for "all kind of amateur electronic interest".
I have no ambitions to design satellite communication stuff and I certainly will not have to "tune" my 24bit audio interface at any time. So neither ultra high resolution nor microvolt noise floor nor gigahertz performance is necessary. Since I just use it for my own, a perfectly streamlined user interface is not the primary selection criteria, as long as it does not hamper the overall function. But then, I AM a male and thus not immune to the "Gear Acquisition Syndrome".
I DID read a lot the previous weeks, watched the relevant(?) videos and tried to keep up with the thousands of posts here that pick apart each and every miniscule specification and usability quirks - which turned out quite difficult. I settled with the following "knowledge" so far:
- The smallest available entry-level model of each brand easily outperforms my old scope hands down and if I had to pay a new one from my own money I certainly would pick that one. But I certainly don't miss the opportunity to invest the budget as fully as possible.
- The Rigols and Siglents are both capable and real-world-usable with a big happy user base for both with the usual concurrency amongst their fans.
- ... and so may other that have not grasped my attention due to the mass of posts that focus on just these brands
- Quite some model lines do just differ in what my license allows me to get from the same hardware. That makes it interesting to rather invest the money in features that are hardware bound and handle the licensing stuff with help from the board
- digital channels might not be as superfluous (= totally out of reach for a hobbyist) as they might have been some years ago. After all, soldering your own digital devices is again as popular today as it has been back in the 1980th, just with much smaller parts and higher frequencies.
So even if it might turn out that I cannot convince the insurance company that the digital probes are "part of the device", it is still an option to add them on my own budget. But if I take a model without that option, I simply lose this possibility and changing my mind later would be much more costly.
What I did not figure out are such things:
While Rigol seems to have more need for bugfixing the software, and it seemingly does this rather slowly, this might still be an option to get a great scope in the end, as long as they DO fix their problems and not declare the device EOL quickly and urge the customers to upgrade to the 2024 model instead "where all is just great". Do they? Have they done in the past? In the old time, things just worked out of the box (or just went back immediately) and kept doing until they really needed some repair. Nowadays all things seem to need permanent and frequent "updates" just to keep them running or ironing out software problems that made it into the release version. I as a hobbyist would accept some release cycles to marture the device as trade in for good overall specifications at a bargain price.
This could nudge me to get an "MSO5074" (+ logic adapter), as I might be able to get that paid fully.
The "SDS2104x Plus" in contrast seems to compet nicely on features, with a better(?) UI but might turn out that I have to add the logic adapter on my own, which likely would not happen at all, as long as I have no urgent need, which might turn out as "never". I had none in the past and I just skipped all projects that would have needed one.
But then, why pick an MSO at all and not one of the DHO1000 models that do fall into the proposed budget too. No MSO, but otherwise fine specs. This is where things start to get complicated again. Trade digital inputs (that I probably not
really need) against vertical resolution (that I probably not
really need either)? My crystal ball is quite dusty and does not show any future need that could help me deciding.
Ever had the problem to spend other peoples money for a "maximum solution" you don't even know?
Splitting the budget into a cheaper scope plus a fancy new SMD soldering station is not part of the insurance contract...
Well, certainly a first-world problem.
I'm open for thoughts.
