Author Topic: Current Probe Recommendation  (Read 15683 times)
Offline woodchips
Re: Current Probe Recommendation
« Reply #50 on: January 19, 2018, 04:35:38 pm »
Knew I should have at least powered them on before posting, but they were all working a few years ago!
Only find one AM503 system, hours of looking have turned up nothing. Even that system isn't working, getting lots of noise spikes at low frequency, presumably the Hall amplifier.
The one 134 system I have tried is completely dead.
Apologies to those who expressed an interest, doesn't look good.
And I had just repaired my 7613 to test them with, that will be useful at least.
« Reply #51 on: January 19, 2018, 09:04:34 pm »
What probe comes with it ?
Would you sell it as 'not working' ?
Offline serggio
  • Country: ru
« Reply #52 on: February 18, 2018, 03:36:12 pm »
I think, HIOKI CT6841-05 + CT9555 also can be interesting
Offline Hydron
« Reply #53 on: February 18, 2018, 04:27:20 pm »
Where in the UK are you? (PM if you don't want to say in the thread).
I ask as I have a known working AM503+A6302 setup (plus a slightly iffy A6303) and could potentially help work out what's wrong. Even just narrowing it down to dead/alive probe is worthwhile given how much an A6302 costs! (while you can pick up a probably-working/fixable AM503 amp for under $50 from the US or occasionally the UK, good luck getting a tested good A6302 probe for below a few hundred USD/GBP!).
