Author Topic: R&S UPGR Psophometer  (Read 1239 times)
Offline MesstechnikerTopic starter
« on: February 17, 2018, 04:37:23 pm »
Apparently been bitten by the bug. :palm: A R&S UPGR Psophometer is on its way to me.
Why? I don't really need it but since I happen to have the full service manual its worth a try.
Fault description by the seller: - supply is shorted.  :scared:  But battery case and meter are OK.
We will see. If the repair and full calibration goes well I'll be out hunting for an matching audio frequency generator
from the same period (ca. 1980) preferably also from R&S. Or from a different European manufacturer. :palm:
Agilent 34465A, Siglent SDG 2042X, Hameg HMO1022, R&S HMC 8043, Peaktech 2025A, Voltcraft VC 940, M-Audio Audiophile 192, R&S Psophometer UPGR, 3 Transistor Testers, DL4JAL Transistor Curve Tracer, UT622E LCR meter, UT216C AC/DC Clamp Meter
Offline egonotto
Re: R&S UPGR Psophometer
« Reply #1 on: February 17, 2018, 06:46:59 pm »
if it works you can measure how many alcohol you have drunk :)
Best regards
egonotto
« Reply #2 on: February 18, 2018, 09:05:01 am »
Well probably not. For details on this seemingly weird term, see here:
https://en.wikipedia.org/wiki/Psophometer :-+
