I don't have any knowledge of the tester, so some generic advice: If you can, measure the ones around it that look the same. It's probably the same value. It looks like a "bulk" capacitor in a power regulator circuit. Also, to get an idea of what the voltage rating might be, measure the voltage on them. You might even get a correct reading across the missing C417.
