Author Topic: 3 channel DDS generator purchase  (Read 2784 times)
Offline KlausKragelundTopic starter
« on: April 10, 2022, 09:15:11 am »
Hi
I have a Siglent 2 channel DDS generator, but sometimes I need 3 channels
I have been searching and sofar no hits
Anyone recommend one? (I would like better quality than Aliexpress :-))
Thanks
Klaus
Offline DC1MC
Re: 3 channel DDS generator purchase
« Reply #1 on: April 10, 2022, 09:31:26 am »
Offline pope
« Reply #2 on: April 10, 2022, 09:41:18 am »
Hi
Thanks
Klaus
Why not getting another one? Do you need 3 channels on the same device?
« Reply #3 on: April 10, 2022, 09:45:50 am »
Yup, almost impossible to find:
https://www.amazon.de/-/en/Signal-Generator-Channel-Frequency-Waveform/dp/B089R4NGL9
 :-DD
Thanks
Actually in Aliexpress using the search term "3 channel signal generator" came up empty. Adding a dash now suddenly showed the product you linked to ("3-channel signal generator"
Thanks for the help
« Reply #4 on: April 10, 2022, 09:47:26 am »
Hi
Thanks
Klaus
I need to be able to apply 3 phase with 120 degrees between them. Does the Siglent SW support linking them together like that?
« Reply #5 on: April 10, 2022, 10:50:19 am »
Hi
Thanks
Klaus
Actually it does:
https://siglentna.com/application-note/multi-generator-synchronization/?pdf=14786
Offline Ground_Loop
« Reply #6 on: April 10, 2022, 12:30:26 pm »
Hi
Thanks
Klaus
I have done exactly this with a Tektronix AWG430.
There's no point getting old if you don't have stories.
Offline maxwell3e10
« Reply #7 on: April 11, 2022, 02:29:34 am »
There is also Wavetek 195, which is 4 channel. It's a little older and has 12 bit resolution, but with a lot of features. It's the same model as Aim/TTi TGA1244 for which one can find documentation.
Offline ledtester
« Reply #8 on: April 11, 2022, 08:26:19 am »
The Siglent DDS units have an external trigger input which can be used to start the output.
For instance, see page 56 (physical page 67) of:
https://siglentna.com/wp-content/uploads/dlm_uploads/2017/10/SDG1000_UserManual_UM02010-E08B.pdf
« Reply #9 on: April 11, 2022, 10:29:04 am »
SDG1000 models have been replaced with SDG1000X, a far better instrument.
These have a Sync output especially for ganging together multiple units.
https://siglentna.com/wp-content/uploads/dlm_uploads/2022/03/SDG1000X_DataSheet_DS0201X_E01H.pdf
Online langwadt
« Reply #10 on: April 11, 2022, 04:00:54 pm »
Hi
Thanks
Klaus
once you have the two phases with 120 degrees between them the last one is just an add and invert ;)
The following users thanked this post: adam4521
« Reply #11 on: April 11, 2022, 06:35:06 pm »
Hi
Thanks
Klaus
Yes, but do you have a box like that just handy?
Come to think of it, why doesn't anyone sell a box that has amplifiers etc, seems like there could be a marked for it, except for the cheap not sure it works Aliexpress stuff
Online langwadt
« Reply #12 on: April 11, 2022, 06:45:45 pm »
Hi
Thanks
Klaus
obviously depends on frequency and load, but in the simplest case an opamp and three resistor would do
Online nctnico
« Reply #13 on: April 11, 2022, 08:19:00 pm »
This is an idea for a new product (power amplifier) I have for a while but so far no time to actually build it.
