Author Topic: Jack Plug Geiger Counter for iOS & Android  (Read 5879 times)
Offline osiixyTopic starter
« on: March 13, 2017, 02:06:40 pm »
Has anybody came across with this gadget
(and have some professional opinion about it)?
https://www.aliexpress.com/item/Newest-Geiger-Counter-Nuclear-Checker-to-detect-X-ray-Nuclear-Radiation-Gamma-Works-with-Smart-Phone/32297459661.html
I do not know but I can see some potential in it.
(Maybe I would give it a try with a Raspberry Pi Zero
or what the hack probably even a esp8266 is enough
to count and there you have it an IOT Geiger Counter)
« Last Edit: March 13, 2017, 02:17:58 pm by osiixy »
Offline crazyguy
Re: Jack Plug Geiger Counter for iOS & Android
« Reply #1 on: March 13, 2017, 02:23:35 pm »
mentioned in the product description it cannot measure background radiation, not so sensitive, it is just a toy
background radiation ~ 0.2uSv/hr
« Reply #2 on: March 13, 2017, 02:24:47 pm »
I am an idiot.
Thanks.
Offline borjam
  • EA2EKH
« Reply #3 on: March 13, 2017, 02:36:14 pm »
An actual working Geiger detector kit is sold, for example, by Cooking Hacks. It works with Arduino or, using a "shield" to "hat" adapter card, with Raspberry Pi.
But it's much more expensive than the Aliexpress toy.
The Cooking Hacks circuit works, it measures background radiation and I have tried it with several radioactive sources (Thoriated TIG electrodes, pieces of Fiestaware pottery, an old light mantle...) and it indeed reacts :)
Offline crazyguy
« Reply #4 on: March 13, 2017, 02:40:25 pm »
you need a known source such as Cs-137 with certificate and proper set-up to calibrate the GM kit, otherwise the reading is meaningless.
Offline mikerj
« Reply #5 on: March 13, 2017, 02:50:23 pm »
It says "Geiger" but I'm pretty sure it will actually be using a PIN diode.  Much simpler and cheaper but also lower sensitivity and would mean it's only useful for gamma radiation and x-rays.
Offline borjam
  • EA2EKH
« Reply #6 on: March 13, 2017, 02:55:38 pm »
Indeed. The calibration is a complex issue and it depends on the purpose for which you are doing it in the first place. I think that
this kind of kits should not display any purported measurement unit like µS/h, just counts per minute. So you know that a piece of pottery gives a much higher CPM count than the usual background level you see, but there's no potentially misleading µS/h value.
What I mean is that the detector works (not that using a Geiger tube is rocket science), it shows a roughly meaninfgful value for background radiation, and it indeed reacts when you place a radioactive source (beta or gamma) close to the tube.
The tube included with the circuit does not detect alpha particles, but they give you instructions to try different tubes. I have purchased a SBM-9 which should detect alphas as well. I'll try it one of these days.
Online Emo
« Reply #7 on: March 13, 2017, 03:00:47 pm »
It would be interesting to know what kind of detector they are actually using. From the same company
http://www.ebay.nl/itm/Smart-Geiger-Pro-SGP-001-Nuclear-Radiation-Detector-Counter-For-Smartphone-iOS-/381593861398?hash=item58d8c43d16:g:Uk0AAOSwSzdXBVAZ
It says ten times more sensitive. Probably just a little bit.....
Offline crazyguy
« Reply #8 on: March 13, 2017, 03:09:43 pm »
not GM-tube with scintillation detector, the spec already said it is semiconductor type detector
« Reply #10 on: March 13, 2017, 03:18:47 pm »
Sorry SBM-9 or SBT-9?
I am only able to find infos for later one.
http://www.pocketmagic.net/tube-sbt-9-end-window-geiger-tube/
Offline borjam
  • EA2EKH
« Reply #11 on: March 13, 2017, 03:23:07 pm »
Silly me, sorry!
It's a SBT-9. I somewhat mixed up SBT-9 and SBM-20.
