Thanks.
just catching up on your new build Joe, you really do finish off projects! Your new generators look beautiful, nice work... can we see inside the new higher energy unit, what volts/capacitance do you have in there?
i still have not figured out the point where the magstim fires, a load of 100k ohm and it wont, but 1k does, i can put a coil in parallel with the DUT but then i am wasting energy in the coil. Your approach to use low energy high voltage to trigger the main charge is interesting... much like a xenon flash tube circuit in a way
i am taking the magstim over to a friend tomorrow, see if we can figure out why i am only getting 1700v instead of 2800v on the cap... i am sure we'll get around to making some things expire too, maybe i should try the fluke 101?
Thanks. Yes, I really "finished this project off" yesterday.
There's not much in them both. The new unit has a power supply, capacitor bank with some protection for it, an output network and a trigger circuit. I originally thought about making the bank using different voltage/capacitance values and then having a waveform with multiple breakpoints. But I already had the generator that could produce several KV, so it was easier to just use the lower voltage caps and design a way to trigger it. The problem I see is that some of the meters I have tested did not break down even with 6KVish. If they don't break down, the second generator is not going to cause any damage.
Are you sure that your generator does not fire? Are you putting a scope across the outputs and looking at them or still using the loop?
With your generator being designed for one specific purpose, they may not have a network like a typical combo generator would have. For a combo, they spec an open and short condition for voltage and current. In the generators I have made, I am keep the open circuit voltage tamed to something like the IEC waveform. But for a short, I don't have the energy available (for good reason). And again, even with the new generator, while I can output a 200V+ volt AC wave while I am injecting the transient, the two are not in sync and the transient is coupled to ground not riding on top of the AC. And, I limit the AC to typically < 50mA but can only go as high as 500mA (for good reason). All that to say, in open circuit mode, the majority of the energy is dissipated in the output network. With a short (or a meter breaking down) some of the energy is dissipated in the output network.
The following paper may be of interest to you.
http://www.denverpels.org/Downloads/Denver_PELS_20070918_Hesterman_Voltage_Surge_Immunity.pdf
