Poll
How many cycles will the KeySight U1281A's detent spring last?
0-2000
7 (16.3%)
2k-4k
5 (11.6%)
4k-8k
16 (37.2%)
8k-16k
8 (18.6%)
>16k (most rubust meter ever made)
7 (16.3%)
Total Members Voted: 40
Author Topic: Handheld meter robustness testing  (Read 1242807 times)
Offline joeqsmithTopic starter
Re: Handheld meter robustness testing
« Reply #4925 on: April 24, 2024, 06:54:34 pm »
Thanks.
Interesting, they went back to a single dimple contact rather than the double dimple.  Plating appears the same.  I've seen them change these contacts over and over again.  I wonder why they can't settle on a design.  I take it you don't have a set of calipers to measure the PCB thickness.   If you lift off the switch contact holder from the brass hex shaft, is there a shim under it?
PCB has some changes.  New clamp design.  I wonder why they changed it and it it improved its electrical robustness.  With it being Dave's meter, I am surprised he doesn't show off the changes and explain the reasons for them.   Maybe he did and I wasn't paying attention.
Just an FYI, I had bought two of these to review.  Showing the board of the unit that was damaged during the grill starter.  Notice the changes.
« Last Edit: April 24, 2024, 06:58:33 pm by joeqsmith »
Offline ploxiln
« Reply #4926 on: April 24, 2024, 07:11:09 pm »
I do have a cheap digital caliper ... just not very experienced, and being a bit cautious/ginger - the reading depends a bit on how much pressure I apply to the jaws. It's probably actually 1.5 mm, that's what I get when applying more pressure.
I don't have a great setup for the close-ups, anyway, some more switch detail ...
« Reply #4927 on: April 24, 2024, 07:34:51 pm »
Measuring mine under the large HRC fuse where there is no copper I measure 1.40mm.  Measuring in that same are with copper on both sides, I measure 1.49mm.  The shim thickness on this meter measures 1.05mm.  Dave had said the shim was made to correct for the wrong thickness of the PCB.  I was expecting yours to measure over 2mm.   May have been a story?
Shown is one of the double dimple wipers from my meter after the 50,000 (full rotation) life cycle test.
Looking at your PCB, the switch contacts appear identical to mine.  I know my meter when set to the LowZ mode does not have enough spacing to prevent it from flashing over at the levels I typically test at.  Looking at this meter, it doesn't appear that I tried that with the higher energy generator as the PCB doesn't appear damaged.
« Last Edit: April 24, 2024, 07:45:25 pm by joeqsmith »
The following users thanked this post: Eltax1693
Offline armandine2
« Reply #4928 on: April 25, 2024, 06:55:12 pm »
Verniers cheap or not can be awkward to get at the right angle, I find, best to use a micrometer.
Funny, the things you have the hardest time parting with are the things you need the least - Bob Dylan
Offline Hydrawerk
The following users thanked this post: BILLPOD
Offline Hydrawerk
« Reply #4930 on: May 11, 2024, 01:07:52 pm »
This has a different case!
« Reply #4931 on: June 03, 2024, 12:23:20 pm »
Neon sign transformer vs DMM
The following users thanked this post: ploxiln
