@Joe
Hi Joe, and first, keep safe and more importantly a big THANK YOU for keeping this thread going and your fascinating testing & analysis of dozens of DMMs over the last 6 years and counting!
I have read of course the rules that you set in your first post in this thread and I hope I am not disrespecting them if I have a request for you: would it be possible for you to test this unassuming, low cost (around $15 including shipping) UNI-T UT125C DMM? What makes it different from others in the same price range is that it is apparently independently certified to conform to UL STD 61010-1, -2-030, -2-033 and -031 and rated CAT III 600V.
It's a tiny thing, comparable in size to the Brymen BM27 which you have tested, only much thicker and mechanically sturdier. Now whether it would pass your gas grill lighter test is an unknown.
I am attaching two pics of the UT125C, a top view and an internal view which shows the PTCs and MOVs and protection diodes in its input path. Curiously there is also a spark gap but the component above it is not present, so I wonder if the spark gap has any use in this case.
Thanks again for your fascinating work!
There are a few problems I see running this meter. First, its a brand known to fail. 13 products so far and all have performed poorly. You're not seriously expecting a different outcome are you?
Another problem I see is how the meter shares the inputs with the current function. The problem there is depending how the meter is designed, the fuse may blow after each transient. For two functions, that's 20 transients for each level, or 20 fuses. I have seen meters like this before and point them out but have not ran them for this reason.
Then there's what you are calling a spark gap. It sure does look like that's the intent with the plated edges. I would hope that gap is not directly across the inputs. If it is and has a UL safety cert, it would just further erode my confidence in these large bodies.
Have you tried to find pictures of the bottom side? You may be able to trace out the front end.
I have a UT90A that has a few spark gaps but I doubt very much these were by design. They breakdown at such a low voltage, I could never permanently damage it. Not doubt there are some idiots who would say that meter is very robust.
![Laughing :-DD](https://www.eevblog.com/forum/Smileys/default/smiley_laughing.gif)
After constructing the half cycle generator, I made another attempt to end it.
