I doubt I would try and power them up during the test and take any readings. While I can believe that with some of the meters, the adjustment pots could move. The bigger problem is that some meters, like the 121GW for example, are sensitive to changing magnetic fields. It's early and I may change my view of this. I can see doing some sort of before and after test for meters along with pulling it apart for inspection.
