Poll
How many cycles will the KeySight U1281A's detent spring last?
0-2000
7 (16.3%)
2k-4k
5 (11.6%)
4k-8k
16 (37.2%)
8k-16k
8 (18.6%)
>16k (most rubust meter ever made)
7 (16.3%)
Total Members Voted: 40
Author Topic: Handheld meter robustness testing  (Read 1261956 times)
0 Members and 37 Guests are viewing this topic.
Offline HoracioDos
  • Country: ar
  • Just an IT monkey with a DSO
Re: Handheld meter electrical robustness testing.
« Reply #3150 on: February 22, 2019, 04:33:44 pm »
Also, curious what would happen if this blew the supply company's service fuse? What would they charge to come out and fix it? And would they ask how it got blown?
It's pretty common here. You can buy a 63A fuse and install it by yourself if you dare. Fuse box doesn't have any precinct. Just a plastic lever inside.
Offline Fungus
« Reply #3151 on: February 22, 2019, 05:06:16 pm »
I was hoping to finish up my testing this weekend for the new meter but ran into a minor setback.  Parts are on order and should make it in next week.
It died much too early?
Offline joeqsmithTopic starter
« Reply #3152 on: February 22, 2019, 06:28:13 pm »
Two years of testing has taught me that the performance is not always proportional to the hype.
To date, I have documented 59 meters.  This does not include a few like the Fluke 189.    In the first set of tests, the AMPROBE AM510 was damaged at 5.8KV which is basically what I call my cutoff point.   Make it above that level, you have a decent meter IMO.  We have 15 that meet that criteria or 25%.    If we include the Fluke 189 and assue that one 87V that I had repaired and reseted to be a flyer, then we have 17 out of 60 or 28.3%.   Of course, I have been running what I consider a better class of meter lately which biases the data.
Of these, the brands that stand out are and Fluke and Brymen.  While the Gossen and HIOKI both did very well, I only looked at one product from these companies.  I have said that I use a HIOKI product for work and personally, that carries some clout after what I have put it through (transient wise).   We are not talking about these little piss ant transients I apply to benchmark these meters.
Statistically speaking, I would say the meter I am looking at now ......   (you don't want me to spoil it for you, do you? lol)    Maybe we will have a new brand join the Flukes, Brymen's, HIOKI's and Gossens of the world.  It's big shoes to fill and requires you know how to design....  Maybe....
Offline Fungus
« Reply #3153 on: February 22, 2019, 06:33:03 pm »
Nope.
« Reply #3154 on: February 25, 2019, 11:51:36 am »
Several people have asked me to look at Yokogawa.   In this video, I have a look at their top of the line TY720.
https://youtu.be/4aCN-uLeO5s
Offline Fungus
« Reply #3155 on: February 25, 2019, 12:37:43 pm »
At least we agree on the correct choice of calculator.  :)
Edit: Real SIBA fuses? The printing on them looked nice in the video, maybe some closeup images.
(or ware those the fuses you posted the other day?)
« Last Edit: February 25, 2019, 03:55:07 pm by Fungus »
« Reply #3156 on: February 26, 2019, 12:37:18 am »
I like this old HP calculator.  Anything more complex, I use the PC.
I saved the fuse in case someone wanted more information about it.   I have no reason to suspect any of the large parts have been counterfeit.   If someone did want to make a knockoff, I would think they would directly crimp the end caps to the body like other cheap fuses we have looked at.
In the comments, one person had posted about also seeing a fuse be intermittent.   Perhaps it's more common than I thought.
Offline malagas_on_fire
  • Country: pt
  • Kernel Panic
    • Malagas Lair
« Reply #3157 on: February 27, 2019, 12:26:35 am »
Hey seems that the DMM have some similar cousins,.. Kyoritsu KEW 1062 :
https://www.kew-ltd.co.jp/en/products/detail/00976/
Copy cat?
If one can make knowledge flow than it will go from negative to positve , for real
Online rsjsouza
  • Eternally curious
    • Vbe - vídeo blog eletrônico
« Reply #3158 on: March 01, 2019, 05:09:59 pm »
Joe, I am really sorry to see how this Yokogawa is really a far cry from the A-brand meters - one could do much better for the same price.
Given Malagas' find above, I really wonder if they OEM this.
Offline sambonator
« Reply #3159 on: March 01, 2019, 05:22:46 pm »
Copy cat?
From what I understand, they're made in the same factory for both Kyoritsu and Yokogawa.  Please see:
https://www.eevblog.com/forum/testgear/ty720-kew-1062-handheld-multimeter-inside-high-resolution-images/msg1491871/?topicseen#msg1491871
The following users thanked this post: rsjsouza, gnavigator1007, malagas_on_fire
« Reply #3160 on: March 02, 2019, 05:43:41 pm »
FanOfeeDIY had asked me about running one (to the extend of offering to send one) of these meters some time ago and posted those pictures to give me some idea how it was designed.  He answered some questions I had as well which is really why I decided to run one.
I did start a thread in the repair section for the meter.  I'm a bit too lazy to blindly start tracing the meter out but maybe someone else has some details about the design.
https://www.eevblog.com/forum/repair/yokogawa-ty720-kyoritsu-kew1062-needs-repair/
« Reply #3161 on: March 03, 2019, 05:49:08 am »
After several of hours of tracing all these analog switches and multiplexers, I now know way more than anyone should ever have to about the TY720.   The board is filled with colored markers and now needs a good cleaning.
To Yokogawa,   :--
Offline sambonator
« Reply #3162 on: March 03, 2019, 07:21:39 am »
What's that capacitor doing there?
  • Country: pt
  • Kernel Panic
    • Malagas Lair
« Reply #3163 on: March 03, 2019, 11:38:06 am »
I believed is being measured by the meter, a 25uF part,  before it gets totally assembled , clean and dry. This way you wont get more surprises to avoid further taking apart
« Reply #3164 on: March 03, 2019, 04:11:03 pm »
Indeed, it was a cap that I was using to test the meter.   Shown, the board after some cleaning.  I have had the shield off three times so far and not seeing a problem with the two solder joints.  Showing the 10uF cap in my test box.   After changing out the analog switches and repairs, the meter needs to be realigned.
Someone had asked if it was possible that the zebra strip was causing the bad contrast.   No.
Someone else asked about a contrast adjustment.  Yes, there is.  The problem is the contrast is already high enough that segments that are turned off are bleeding through.
Another person attempted to read a biased AC voltage and was able to repeat what I saw with this meter.
Online rsjsouza
  • Eternally curious
« Reply #3165 on: March 03, 2019, 04:42:54 pm »
I feel your pain. I started to extract the schematics of the Surpeer AV4 and suddenly the same thought came to my mind. I then closed everything and sold it for the same price I paid (with all the proper disclaimers, of course).
  • Country: pt
  • Kernel Panic
    • Malagas Lair
« Reply #3166 on: March 03, 2019, 04:59:05 pm »
Jesus did i wrote 25uF??? i mean t22uF :P Sorry. It was off then but now looks very accurate, and a lot hard work invested in cleaning that flux . Did you also touched some solder joints? they look very shinny.
« Reply #3167 on: March 03, 2019, 05:16:10 pm »
I was really hoping someone would show up with the schematic for it.  It would have been a quick repair then.   I could have left it damaged but I have made a point to attempt to troubleshoot the meters that are damaged during the testing.   With this meter using mostly standard parts, I was confident it could be repaired if I wanted to invest the time.  The spaghetti design added to the challenge.  In the big scheme of making the video, it wasn't too bad.
I looked at buying one of the AV4 meters but from the pictures I saw, it looked like it had no protection, similar to the ANENG meters I have looked at.  That OWON I looked at did a fair job functionally.  Had the Bluetooth interface been documented,  better input protection and some proper fuses, it would make a nice meter lower cost meter.
« Reply #3168 on: March 03, 2019, 05:20:59 pm »
When it was all said and done, I had removed and reattached 13 ICs and several other parts.   I did blend in some 60/40 on the tabs for the shield to lower the temp.  The rest, I just added flux and reflowed the parts.  My PACE tweezers and heat gun were getting a work out.
« Reply #3169 on: March 07, 2019, 04:05:53 am »
The correct parts arrived for the Yokogawa today.  Seems to be in cal.
https://youtu.be/Q9JhJm_dTPM
Offline sambonator
« Reply #3170 on: March 07, 2019, 12:18:19 pm »
Watched the video but you only touched on the real issue... it was a fuse, but it wassn't one of the two main fuses?  Or was it?  You have us all in suspense  :-DMM ???
« Reply #3171 on: March 07, 2019, 06:22:39 pm »
The meter did have what appeared to be a defective SIBA branded fuse that I replaced early on.   I don't feed the transients into the current inputs of the meter so no, the damage to the capacitance mode had nothing to do with my changing out that fuse.   That was a completely separate problem.
Normally on the better class of meters, the high speed clamps will fail and save the down stream components.  On the low end meters, normally something else in front of the clamp (normally the PTC) will brake down and it's game over.   In this case, the entire front end checked out.  This may be a first.   It also tells me that the meter could use some improvements.   It has enough other problems that it's hardly worth spending more time on though.
  • Country: pt
  • Kernel Panic
    • Malagas Lair
« Reply #3172 on: March 07, 2019, 07:45:25 pm »
Here is another Japanese meter that may look interesting:
https://overseas.sanwa-meter.co.jp/items/detail.php?id=13
It has nano siemens at least :P but the contrast seems a little dim from the catalog and pictures.
[Edit]
Not a newer model for sure.... it has been reviewed and digits are more slim but not too dimmed . Capacitance reading is quite fast
« Last Edit: March 07, 2019, 07:51:44 pm by malagas_on_fire »
Offline sambonator
« Reply #3173 on: March 07, 2019, 08:26:04 pm »
I sense that Kyoritsu/Yokogawa designed that meter to be built with low cost parts and low-cost labor (Thailand) to maximize profit.
AFAIK Hioki is the only Japanese brand that still make their meters in Japan with their own ICs.  Hioki LCDs seem to have the best readability from extreme vertical angles (from below and above).
Offline sambonator
« Reply #3174 on: March 07, 2019, 08:43:08 pm »
[Edit]
I can't get past the Sanwa PC7000 aesthetics... but what is interesting is the 500,000 count DCV mode, and its low cost ($270 shipped from Japan).
I think its manufactured in China.
